Author Topic: SeekOFix vs libseek-thermal -- image processing?  (Read 5032 times)
Offline flyingfishfingerTopic starter
« on: November 09, 2017, 12:31:06 am »
I'm not a programmer so please bear with me. I was playing around with the version of SeekoOFix that was modified to work with the Seek Pro and also the libseek-thermal by Maarten Vandersteegen.
The camera works  great with both, but I noticed the image looks markedly better in SeekOFix than it does with libseek-thermal (the adjustable temperature limits notwithstanding), so I was wondering what kind of post-processing SeekOFix does that libseek-thermal does not.
I know I could dig through the code and find out, but I know very little of each so that would be fairly involved for me. I'm not looking for in-depth analysis, just wondering what the fundamental differences might be that appear to make the SeekOFix image that much better.
Thanks,
Rafael
Offline frenky
  • Country: si
    • Frenki.net
Re: SeekOFix vs libseek-thermal -- image processing?
« Reply #1 on: November 09, 2017, 07:29:54 am »
As a developer of SeekOFix  I can tell you how I did it.
It is quite simple:
Remove all bad pixels; adjust gain of every pixel; display first frame after shutter calibration...
https://github.com/frenkinet/SeekOFix/blob/master/TestSeek/Form1.cs
« Reply #2 on: November 09, 2017, 04:53:53 pm »
Thanks, that helps a bit. I built the project and poked around the code a bit; it's s a very nice app.
Any idea what it would take to build it for Windows Universal?
Cheers,
R
Offline frenky
  • Country: si
    • Frenki.net
« Reply #3 on: November 10, 2017, 12:01:54 pm »
No sure...
I have put Win10 on RPI and it did recognise SeekThemal module so I guess it is possible to do it...
Offline tonykids
« Reply #4 on: November 10, 2017, 02:42:34 pm »
in fact I just modified some variables and init command in SeekOFix, no extra processing.
if you use the internal reference frame,I think the two are the same.
but when using the external reference frame,libseek-thermal does some average processing and libseek-thermal seems better than SeekOFix on my computer?
« Reply #5 on: November 10, 2017, 07:25:16 pm »
Interesting. Using external reference frames, SeekOFix (or rather, your fixed version to work with the Pro) on my computer seems to deliver a much better image (maybe it's the  color mapping, but there seems to be much more detail) which is why I'm wanting to use it.
I'm trying to get the VS project to build a UWP package that can be deployed on Win 10 IoT; apparently it's supported but I need to get it to run normally first with the Pro modifications.
R
« Last Edit: November 10, 2017, 07:27:15 pm by flyingfishfinger »
Offline KrisMcLean
« Reply #6 on: February 03, 2018, 01:13:01 am »
I've got a couple of SeekThermal cams, both are much the same with the Android app. However they are quite different with https://github.com/maartenvds/libseek-thermal  Camera1's ffc.png is https://www.dropbox.com/s/6488ttflzmfzlad/1ff.jpg?dl=0 & it makes good photos. Camera2s ffc.png is https://www.dropbox.com/s/6upqsnmq9qwss6d/2ff.jpg?dl=0, it has a circle with flare halo & makes compromised photos https://www.dropbox.com/s/c0464prz8xlg4k2/2flare.jpg?dl=0 Just wondering what the Android app is doing to deal with the halo that the libseek based C+ code is not?
« Last Edit: February 03, 2018, 01:24:38 am by KrisMcLean »
Offline Majoren
« Reply #7 on: February 14, 2018, 10:37:09 pm »
did seekofix work on windows iot?
