I want to buy a thermal cam to inspect some electronic boards to repair with voltage injection.
It's for hobby (I'll use it also for some house analysis), so I'll buy a low cost one: I think about 350€ max.
I'm looking at these, it seems all are capable of near focusing 15cm:
1) seek Compact 289€
or Seek Compact XR 349€
focusable lens
thermal sensor 206x156
8-14um
Compact: FOV: 36° 15cm 9Hz
Compact XR: FOV: 20° 15cm 9Hz
Pro: manual focus, 20°?
Cons: less sensor res, 9Hz
2) HT-201 345€
fixed lens
ht-201: thermal sensor 320x240 8-14um Field angle/focus length 26°×34 15cm 9Hz (but I saw 15fps with ThermoVision on W10)
(for comparison, Ht-301 (too much money...): Field of view: 28.2 * 21.3 Lens: 13mm)
Pro: better sensor, 15fps on W10 (but I suppose also Seek could do it with thermalView)
Cons: fixed lens
video with 201 + CO2 lens at 15fps:
So:
1) FOV: Which FOV (or focal length) is better to inspect boards? 20°-26°-36° ?
2) MACRO: Is 15cm focus sufficient? Or which macro lens should I buy to achieve better result? With the XR 20° is it still necessary a macro lens? Will it focus anyway better?
3) MANUAL FOCUS: Is it really manual focusable better than HT fixed one? I saw many here bought HT-301...
