Author Topic: Thermal image side by side with radiometric image?  (Read 1968 times)
Offline Abbott242Topic starter
« on: February 08, 2024, 09:24:48 pm »
Hi all,
I'm trying to interface with a new core via UVC, but the results I'm getting... Well, speak for themselves. I assume this is a result of the core sending radiometric and video data at the same time? This was just via using the default Windows camera app for a quick test.
I would appreciate any help in trying to diagnose the problem, as this is a first for me. Thank you!
-Abbott242
Offline Bud
Re: Thermal image side by side with radiometric image?
« Reply #1 on: February 08, 2024, 09:52:37 pm »
Try reversing the byte order in the right half of the image.
« Reply #2 on: February 09, 2024, 07:16:48 pm »
I'm not entirely sure what you mean... This is just a uvc camera - I don't think I can change each half of the image separately? But then again I'm not terribly experienced with software.
Offline LesioQ
  • Every king should be naked.
« Reply #3 on: February 24, 2024, 06:11:23 am »
Offline IR_Geek
« Reply #4 on: February 24, 2024, 12:29:38 pm »
what size is the array supposed to be?   one picture you show is 3636x1496 and the other is 2720x1496  ;  what is the digital bit depth of the camera ... 8 bit, 12 bit, 14 bit?    You should be able to calculate your raw digital counts.   ignore the color as that is just a color map being applied.
if possible set the camera in RAW without a color map (or just grayscale) and look at the native bit depth.   0-255 ; 0-4095; 0-16383;  even better if the camera has a test pattern so you can verify output.
Offline IR_Geek
« Reply #5 on: February 24, 2024, 12:38:26 pm »
Also what was mentioned above about byte order.   Another is where the 'data' is stored inside the stream.   for 8 bit it could be packed into a 16 bit stream.  Then it must be pulled apart and applied correctly.  Could still be byte swapped.   if it's 12 bit in a 16 bit then need to verify where the zero are located ... first 4 our last 4.   If the camera vendor is a real PITA then maybe 2 zeros in the front and 2 at the end.
OR the other data location is where the temperature calibration is being stored if it doesn't have a header for each frame.
Offline figment
Would this be a ICI Titan 1280 or Helios 640?
« Reply #6 on: March 01, 2024, 12:23:00 am »
What camera model are you working with? I have a USB thermal camera that gives the same mirrored double image.
