Author Topic: Thermal Imaging Gallery  (Read 116944 times)
Offline Vipitis
  • aspiring thermal photography enthusiast
Re: Thermal Imaging Gallery
« Reply #250 on: November 20, 2018, 03:33:23 pm »
My images also highly increased by moving to a premium app. It was only very small price but it god rid of the stupid blur FLIR is forcing upon us. I had an ongoing conversation with the developer of ThermalCamera+ via email. As far as I know development halted but there are still lots of improvements and bugs to work on.
This being a gallery here are some images:
My left hand with a hurt finger and a "dark frame" using my DIY optics that highlight issues such as vignetting, leak, lens imperfection and sensor bias.
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
« Reply #251 on: November 21, 2018, 08:35:49 am »
Although I've posted this elsewhere on the site in answer to another question, I think this is just about pretty enough to qualify for the gallery:
It's a simple electric wall heater, taken with a ThermApp Pro and ThermViewer, but with the palette messed about with in Paint Shop Pro X. I like the rather psychedelic result.
Rubber bands bridge the gap between WD40 and duct tape.
Offline elninjo888
  • Country: lt
« Reply #252 on: November 21, 2018, 09:49:59 am »
Here is a Bosch impact driver after some work.
Sent from my SM-G930F using Tapatalk
Offline Ultrapurple
« Reply #253 on: November 21, 2018, 11:31:37 am »
What imaging setup did you use?
Offline elninjo888
  • Country: lt
« Reply #254 on: November 22, 2018, 11:17:35 am »
Super resolution is on,
first picture - enhanced pallet is on,
second picture - image enhancement with sharpening edges,
third - non,
fourth - non
I am using Xtherm T3s camera.
Offline mahony
« Reply #255 on: November 24, 2018, 06:12:04 pm »
Played a little bit with close-up work using the 14mm Ophir lens and the 35mm.
With the 14mm you can get as close as ~30mm to the subject leading to the Euro coin being full screen than. The resolution here is roughly 48µm per pixel or magnification of ~0.3x. You might be able to get even closer, but the lens was only half a turn screwed into the the adapter in this configuration AND you already start getting serious non-flat image plane (the borders of the coin are already blurred noticably) and depth of field is really shallow. With all the longer focal lengths you need even more distance between lens and detector for similar working distances ... with some modified adapter I think 1.0x magnification might be possible. Anything even higher might be possible with two of those lenses or maybe a combination of the 14mm and 35mm?!
Subject 1: Teensy 3.2 on a small DIY board (my 'Blackbody' controller)
Subject 2: 1 Euro coin
Camera:   TE-V1
Lens 1:    14.25mm f/1.2 (teensy close up and coins)
Lens 2:    35mm f/1.4 (teensy far)
Postprocessing: non (linear mapping to gray scale for the teensy / the coins are logarithmically mapped to gray scale)
« Last Edit: November 24, 2018, 06:14:02 pm by mahony »
Offline Ultrapurple
« Reply #256 on: November 25, 2018, 12:46:21 am »
Somewhere - ebay.COM I think - I saw someone offering a macro extender ring for Therm-App cameras but I think they would work with other cameras. The price was something like US$40. The curious thing is that the vendor claimed to be in London but even searching on the eBay item number it did not appear on ebay.co.uk. Go figure. Anyway, it loomed like the perfect cure for the wobbly lens macro issue. Haven't tried one (yet) though.
Offline cuda12
« Reply #257 on: December 09, 2018, 02:14:59 am »
Flir E30 upgraded to E60
Flir 30mm lens
30 foot plus to shot
« Last Edit: December 09, 2018, 02:38:01 am by cuda12 »
Offline Mr. Scram
  • Display aficionado
« Reply #258 on: December 09, 2018, 02:26:15 am »
There are some really impressive pictures in here.
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
« Reply #259 on: January 02, 2019, 08:17:08 am »
Wall mounted heater.
i3 TE Q1 Plus:
Upscaled with waifu2x.
Offline Ultrapurple
« Reply #260 on: January 02, 2019, 08:49:06 am »
That looks nice - and Waifu2x has done a good job. Try starting the heater from cold and taking images as it heats up - you can get some interesting heat distribution patterns.
The following users thanked this post: frenky
  • Country: si
    • Frenki.net
« Reply #261 on: January 02, 2019, 12:44:27 pm »
Will do that but I must first upgrade my custom software to enable locked thermal range on sequence of  images.  :P
Wood cook stove at my mother in law:
Online Bud
« Reply #262 on: January 03, 2019, 10:53:28 pm »
I tried waifu2x with a liberated E4, the images below are the JBC soldering station and mains voltage stabilizer, upscaled in photo mode by 2 from 320x240.
« Last Edit: January 03, 2019, 10:55:57 pm by Bud »
Offline ARD
« Reply #263 on: January 04, 2019, 05:42:40 pm »
Here is my truck after commute back home
  • Country: si
    • Frenki.net
« Reply #264 on: January 13, 2019, 11:26:05 am »
Oatmeal.
ThermalExpert Q1 Plus:
Offline flolic
  • Country: hr
    • http://filiplolic.com/
« Reply #265 on: January 13, 2019, 02:03:18 pm »
Insight L-3 CNVD-T thermal night vision
(Video taken by holding mobile phone camera against L-3 CNVD-T eyepiece)
Offline OrBy
« Reply #266 on: January 15, 2019, 05:02:53 am »
Some stuff I have done with a modded E4.
Offline 7gone
  • Country: lt
« Reply #267 on: January 17, 2019, 07:13:27 pm »
Seek Thermal PRO FF, somewhere around 16-17HZ, but feels like a little less...
Offline Dark Volter
« Reply #268 on: January 18, 2019, 05:40:24 am »
Hey Ultra, do you know of a easy way to change palettes after a photo is taken? I have my Therm -App HZ and have been looking for software to easily do it- I can somewhat do it in Photoshop, but it's finicky and tricky, even when I try creating custom gradients.
I see IRT Cronista is a thing, but apparently only demo versions can be obtained that last a short time- so that's no good for the simple post-altering I am wanting to do in particular....
Offline Ultrapurple
« Reply #269 on: January 18, 2019, 08:59:21 am »
I've not really explored this. I often manipulate by converting to RGB or HSL or CYMK and playing mix-and-match but that's my limit and I very rarely post the results. I have a feeling that Paint Shop Pro (which I still use after all these years) has a palette load/save function and I'd expect other applications to have similar functions.
Wavelength Pro was/is a piece of software intended to manipulate images from a multi-spectral viewpoint, and may be of some use.
I regret that I haven't read the joe-c software thread but someone more knowledgeable could doubtless tell you if the software there would meet your needs.
Image made using two three exposures with different palettes:
« Last Edit: January 18, 2019, 09:07:01 am by Ultrapurple »
  • Country: si
    • Frenki.net
« Reply #270 on: January 18, 2019, 09:06:37 am »
I see there is some kind of export feature implemented in ThermApp android app:
https://therm-app.zendesk.com/hc/en-us/articles/204503801-How-can-I-use-IRT-Cronista-to-analyze-Therm-App-TH-IR-images-
If somebody sends me this exported files I can take a look at it and maybe implement conversion to different palettes into my free app:
https://www.eevblog.com/forum/thermal-imaging/i3-thermalexpert-custom-software/msg2115976/#msg2115976
« Last Edit: January 18, 2019, 09:10:51 am by frenky »
Offline Ultrapurple
« Reply #271 on: January 18, 2019, 09:11:05 am »
I don't have Cronista but I do have ThermViewer, which produces text temperature dump files and suchlike. Give me a little while and I'll send you a PM with a link to some sample files and the corresponding images.
I think ThermApp Plus also does something similar. Again, I'll investigate. I know it can also produce a 16-bit raw TIFF but I've never had any luck exploiting that data (others have, though). Work beckons at the moment but with any luck I'll get something to you in a day or so.
Offline TooQik
« Reply #272 on: January 18, 2019, 09:33:27 am »
Hi all,
I've got no experience with thermal imaging at this point, hoping to buy a thermal imaging camera soon so I've been lurking in the forum for the last week reading everyone's informative posts.
Thought I'd signup so I could share the following in the hopes it might be able to do what you're looking for.
I have used an open source program called Paraview for some finite element analysis work which uses palettes to show stresses in materials similar to those seen in thermal imaging:
https://www.paraview.org/
Might be worth a look.
Offline PA2001
« Reply #273 on: January 19, 2019, 12:29:05 am »
Bike Headlight
Therm-app
19mm lens
ThermViewer App
« Last Edit: January 19, 2019, 12:48:56 am by PA2001 »
Offline Mr. Scram
« Reply #274 on: January 19, 2019, 12:42:32 am »
How do you do the larger images? Do you automate that in some way?
