I understand a shutter is needed for NUC, because sensor pixels behave differently in different temperatures, and may produce fixed pattern noise. But many (old) imagers have both sensor temperature stablizer and shutter at the same time, why? If the sensor can have a stable working temperature, then it should have a known behavior for every pixels, and can work without a shutter, like cooled ones, right?
Also, newer uncooled cameras seems to get rid of the temperature stablizer, and recently some shutterless TICs appeared, how do these happen?
