Author Topic: CM435_V2  (Read 305 times)
Offline Scorpii_xyzTopic starter
  • Country: cl
CM435_V2
« on: August 06, 2026, 12:37:54 am »
Hi everyone, does anyone know or has worked with the CM-435 V2 (Ampro/ADLINK CoreModule 435, revision 2, silkscreen marked 'CM-435 V2 GP')? I'm trying to get it running and need help identifying a connector.
I only managed to find the reference manual for the standard CM-435, but it differs from the V2. The standard manual describes a 44-pin video header (J11) and doesn't mention any 26-pin connector. My V2 board only has a single 44-pin header (which matches the IDE pinout instead), plus a separate 26-pin shrouded header (missing pin 14) nearby — I'm not sure if this is the video output or possibly a parallel port (LPT/DB25), since both are common uses for that connector style on industrial boards.
Any help identifying this connector, or a link to a V2-specific manual/schematic, would be greatly appreciated. Thanks in advance!
