Author Topic: EEVblog #306 - Jim Williams Pulse Generator  (Read 305904 times)
Offline G7PSK
  • It is hot until proved not.
Re: EEVblog #306 - Jim Williams Pulse Generator
« Reply #550 on: November 17, 2014, 04:28:40 pm »
I think the new job was mentioned on the Amp-hour a while back. something to do with Tesla I believe.
Offline VintageTekFan
« Reply #551 on: November 17, 2014, 04:30:39 pm »
this thing has been slipping , vacation , changing jobs , remodelling the lab..
I hope the job change was for the better!
The three laws of thermodynamics:
1. You can't win.
2. You can't even break even.
3. You can't get out of the game.
Offline AwArD_RzD
« Reply #552 on: November 19, 2014, 01:05:13 pm »
Count me in for a kit !
Offline msraya
  • EA7EE
« Reply #553 on: November 19, 2014, 01:27:49 pm »
I'm interested also in one unit.
Please send me some information when you can..
I have a Agilent MSO9404 Scope wandered here in the lab with some 4GHz bandwidth that I want to test  :-+
Thank You for the good job!
Regards
Manuel
« Last Edit: November 19, 2014, 01:29:28 pm by msraya »
Offline free_electron
    • SiliconValleyGarage
« Reply #554 on: November 19, 2014, 03:52:44 pm »
changing jobs
Thanks!
What is new job?  Please fill us in.
i am now lead PCB designer at Tesla motors.
Offline alank2
« Reply #555 on: November 19, 2014, 04:00:25 pm »
Excellent!  :)
Offline Gixy
« Reply #556 on: November 19, 2014, 09:27:18 pm »
Hi Vince,
I confirm my interest for one kit, I just bought your book on SMT to improve my skills on these little things  :). I just had a PM on my profile.
I'm an old reader as I already had your first book on Electronic with VB!
Thanks a lot and wish you all the best in your new job. Great cars!
« Reply #557 on: November 19, 2014, 09:46:28 pm »
Awesome  :-+ :-+
1. You can't win.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #558 on: November 21, 2014, 07:39:49 am »
Nice! :-+
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline dr.diesel
« Reply #559 on: November 21, 2014, 12:08:39 pm »
We all know Tesla is on the cutting edge and has lots to protect, but hopefully you'll be able to share some of the coolness with us.
Offline etl17
« Reply #560 on: November 25, 2014, 11:49:16 pm »
+1 for a kit (if it's not too late!)....
Offline croyleje
    • LazyLinux
single pulse from Jim Williams Pulse Generator
« Reply #561 on: November 30, 2014, 10:46:46 pm »
Hi Everyone,
I have built a pulser similar to the original design the one i build is from AN61 Triggered 250PS Rise Time Pulse.  The reason I went with this design is so I could have a manual trigger single pulse but I have tried using a simple momentary push button but the switch bounce is giving me issues and when I tried putting some debounce in the circuit I believe it was the cap that then caused issues.  Looking for a simple idea on how I could trigger a single very fast pulse for testing my scopes and other things in the future?  No real reason I only want to be able to trigger the single pulse just like that idea more then the repetitive pulse of the original.
Thanks Jason
http://cds.linear.com/docs/en/application-note/an61fa.pdf
couldn't post whole pdf here is link page 21 and 22
Offline vasilistzo
  • Country: jp
« Reply #562 on: December 04, 2014, 02:19:15 pm »
+1 kit please for me .
I ve been reading all the posts since 2012 for the last few hours.
Offline motocoder
  • Electrical Engineer
« Reply #563 on: December 05, 2014, 02:47:32 am »
i have receive about a hundred bare boards. this thing has been slipping , vacation , changing jobs , remodelling the lab..
i  need to pick this up again. lemme do some homework tonite.
If it's not too late, please mark me down for one kit.
Congrats on your new job, too.
Offline AlessandroAU
« Reply #564 on: December 19, 2014, 03:39:44 am »
Does any know what changes I could try make to make the top of my pulse flatter?
Offline marshallh
    • retroactive
« Reply #565 on: December 19, 2014, 04:01:31 am »
Get a scope with more bandwidth?
That's a pretty good result for a 1Meg input with I assume a feedthru termination
Verilog tips
BGA soldering intro
Offline Jay_Diddy_B
« Reply #566 on: December 19, 2014, 04:05:03 am »
Can you post your schematic and a photograph of your circuit?
And have a look a the pdf document attached to this post:
https://www.eevblog.com/forum/projects/transmission-line-avalanche-pulse-generator/msg185639/#msg185639
Regards,
Jay_Diddy_B
« Reply #567 on: December 19, 2014, 04:19:59 am »
Regards,
Jay_Diddy_B
The pulse generator uses a 2n2369 with a 1pf tank cap and 1m of semi rigid coax.
Are the waves in the top of the pulse caused by internal reflections past the 50ohm feedthrough terminator?
Offline Jay_Diddy_B
« Reply #568 on: December 19, 2014, 01:17:37 pm »
Some of what you are seeing is the scopes performance. The top of the screen says 1G sample per second and 60 points. I assume that there are only 60 samples for the information displayed. The scope is joining the dots between the samples. I don't know if the Rigol scope has an option to highlight the data points or turn off the vectors.
If you turn on a second channel, the sample rate, per channel will drop to 500 Ms/s, and see if this changes your waveform.
This scope picture from my TDS744A converted to a TDS784A has 100 G samples per second, equivalent time, so there is 100 time more information used build the waveform. This requires a repetitive waveform to acquire all the samples.
Regards,
Jay_Diddy_B
« Last Edit: December 19, 2014, 01:29:22 pm by Jay_Diddy_B »
Offline Gixy
« Reply #569 on: February 04, 2015, 01:02:07 pm »
No news from Vincent concerning kits' availability? He seems to be very busy testing DEX  :-/O
Offline silicon_ghost
« Reply #570 on: April 08, 2015, 03:14:32 am »
On the slim chance I can still get one...
+1 kit for me please
Offline moocow
« Reply #571 on: July 22, 2015, 04:43:26 pm »
Probably a long shot, but any way to get one of these still?
Offline DarthBubba
« Reply #572 on: August 05, 2015, 05:30:22 pm »
Once again, late to the dance...    :palm:
@Free_Electron, any pulse generator kits still available?  I'm here in the 'States so mailing/customs would not be a problem.   :-+
PM/email also sent to you.
Thanks,
« Last Edit: August 07, 2015, 02:26:26 am by DarthBubba »
Offline dadler
« Reply #573 on: August 06, 2015, 08:35:58 pm »
Can someone just post a gerber or put the layout on OSHPark?
I searched and couldn't find the layout anywhere.
Offline HighVoltage
« Reply #574 on: August 07, 2015, 07:51:55 am »
+1
I am also really interested in that oine.
Thanks to anyone that can help with this.
