Author Topic: Philips PM 6667 Frequency Counter  (Read 22211 times)
Online xrunnerTopic starter
  • hp>Agilent>Keysight>???
« on: May 04, 2015, 10:04:18 pm »
Got this little guy off Ebay. Plan to clean/restore it. It appears to be circa '79/'80, and has an Intel 8048 microcontroller (one of Intel's first). I did find the manual online. Will post more pics soon. Says "Made in Sweden" on the back plate.  :-+
At the moment it smells highly of nicotine ...  :rant:
Offline pascal_sweden
  • Country: no
Re: Philips PM 6667 Frequency Counter
« Reply #1 on: May 04, 2015, 10:09:43 pm »
Interesting to read that Philips has "Made in Sweden" gear  :)
More typical is "Made in Belgium" or "Made in Holland".
Cool restoration project!
The Philips PE 1542 power supply is Made in Belgium.
That's another cool restoration project. Maybe your next! :)
Offline Shock
« Reply #2 on: May 04, 2015, 10:11:42 pm »
Some of the high resolution digits appeared to have fallen off the right hand side of the display.
« Reply #3 on: May 04, 2015, 10:27:22 pm »
LOL - that's what I thought! But it says so, so it must be true.  :-//
Here's one more for today. I don't know what the green flowery sticker means.
Offline HighVoltage
« Reply #4 on: May 04, 2015, 10:35:15 pm »
I have two of these great counters.
One is in brown / dark housing and one is in a grey housing
I do not recall, where they are made, will have a look tomorrow.
Most astonishing fact is the accuracy after so many years.
« Reply #5 on: May 04, 2015, 11:09:20 pm »
This one is grey, with a light coating of cigarette smoke.  ???
Well, this one is certainly accurate to less then 100 Hz at 100 MHz, but of course those digits are not available. However I will also check it at 10 MHz and less.
Online edavid
« Reply #6 on: May 05, 2015, 12:03:28 am »
In this case, "high resolution" is marketing-speak for a reciprocal counter.
« Last Edit: May 05, 2015, 01:26:40 am by edavid »
Offline Vgkid
« Reply #7 on: May 05, 2015, 01:16:02 am »
Cute little counter.
Offline dom0
« Reply #8 on: May 05, 2015, 07:52:36 am »
Philips made T&M stuff in Belgium, Holland, Sweden and Germany as far as I know.
Most generators (entire PM513x series, PM519x series etc) were made in Germany, counters were made in Sweden (probably why Pendulum is Swedish, too), scopes were Holland.
Offline HighVoltage
« Reply #9 on: May 05, 2015, 09:28:27 am »
Both of my PM6667 counters are made in Sweden.
Interestingly, I never noticed that before.
Here are some pictures of both counters, hooked up to a 1 MHz sine signal.
Offline EEVblog
« Reply #10 on: May 05, 2015, 09:32:24 am »
The PM6666 is an excellent little counter/time to put on your watch list, probably the best of those small Philips counters. Hard to find them with an oven option though.
Offline dom0
« Reply #11 on: May 05, 2015, 09:36:12 am »
Many of the PM6666 around have the GPIB option not installed, too. (Which is a "don't care", depending on what it is for). The PM6654 might be interesting, too. It's essentially the larger and faster lab version.
« Last Edit: May 05, 2015, 09:38:20 am by dom0 »
Offline HighVoltage
« Reply #12 on: May 05, 2015, 09:43:21 am »
There is also a PM6669, also small and reliable.
But I also think the PM6666 was by far the best one.
Just make sure to exchange the mains power connector, if it has the line filter installed.
They like to let the magic smoke out and even get on fire.
I have exchanged them on all my Philips counters.
Offline dom0
« Reply #13 on: May 05, 2015, 10:33:17 am »
Oh and the little cutie, I'm not sure about the number, I think it was PM6661. Not even reciprocal I think.
/e: Yes, Google image search confirms "PM6661" = "cutie".
« Reply #14 on: May 05, 2015, 11:55:25 am »
HV,
I noticed yours have a little test point (?) for the 10 MHz ref. Is that what it is near the bottom, or is it a screw adjustment? Mine does not have that, must have been added to later models.
Offline HighVoltage
« Reply #15 on: May 05, 2015, 01:11:53 pm »
Hello xrunner,
Yes, both of them have this little output pin as a testpoint.
It looks like a screw but it is not.
Here are some closeup pictures from the outside and the inside of this pin.
Just for fun, I hooked up my Agilent counter to this pin.
See results in the picture.
Not bad for a low cost counter from 1986 (Based on date codes on chips)
Offline G0HZU
« Reply #16 on: May 05, 2015, 02:10:21 pm »
For anyone thinking of buying a counter like this: IMO the PM6667 is a bargain basement 7 digit reciprocal counter that is very slow. Probably best suited for looking at divided down digital clock signals where its reciprocal operation will be useful at very low input frequencies. It would be a PITA to use even for basic for ham/CB radio alignment because of the slow update rate and limited resolution.
Note: I have an old PM6669 universal counter here and it is a similar size and is a much better counter than the 6667. It's a universal counter with more features, faster display and 9 digits instead of 7. It's only an inch wider than the PM6667 and maybe 2 inches deeper on a shelf.
But I don't rate either of the 6669 or 6667 as a good choice as a first counter as they both have a gloomy LCD display and the standard timebase oscillator performance is quite poor on both of them. The MTCXO option doesn't offer very good performance so to get the best from the PM6669 you need to feed it an external reference. I don't think you can get an oven option on any of these counters. The triggering/stability performance on noisy signals is probably average. You also have the exploding mains inlet filter issue to worry about. There are better choices out there.
« Last Edit: May 05, 2015, 03:03:15 pm by G0HZU »
Offline G0HZU
« Reply #17 on: May 05, 2015, 02:44:02 pm »
I had a look on ebay and the prices for the PM6666,7,8,9 counters seem very high. Even for the PM6667.
I paid something like £85 for my (very scruffy) 1.3GHz PM6669 about 20 years ago and although this was a huge bargain back then I wouldn't think these counters are worth more than £150 today even for a tidy example. But some ebay auctions are asking £700 which seems a tad optimistic to me...
« Last Edit: May 05, 2015, 02:45:58 pm by G0HZU »
Offline G0HZU
« Reply #18 on: May 05, 2015, 03:21:17 pm »
My 6669 probably has a similar circuit for the standard timebase oscillator although it sits on a little plug in PCB in the 6669.
I can't remember when I last tried to adjust the 6669 but it's warmup drift performance isn't that good.
Usually it starts off reading about +10Hz high (if fed an accurate 10MHz signal) and over about an hour it drifts down to maybe -5Hz and depending on the ambient temparature it usually ends up within a few Hz of 10MHz. But a lot depends on the temperature in the room.
The outer case of the PM6669 counter has to be removed when adjusting the (standard) reference as it has a variable capacitor next to the crystal and this is deep inside the counter. I never liked doing this because the frequency shifts slightly as soon as the outer cover is removed so it demands an iterative and very fiddly/slow approach to adjust it with any precision.
« Last Edit: May 05, 2015, 03:49:41 pm by G0HZU »
Offline gfiber
« Reply #19 on: May 05, 2015, 03:24:51 pm »
I have the PM6676 1.5 GHz version, would like to have a High Stability time base oven for it. Right now it is connected to my Trimble Thunderbolt, but the Timebase oven would make it more portable too.
Gary K8IZ
Offline switcher
« Reply #20 on: May 05, 2015, 03:25:20 pm »
I've never been keen on bench instruments with LCD displays, their visibility is very dependent on prevailing light, and I think the OP's pic demonstrates this.
Offline HighVoltage
« Reply #21 on: May 05, 2015, 04:07:10 pm »
It always depends on the application.
I have some usage for these old and simple Philips counters for sensor testing were I only need 3 digits, then they are very handy.
There still seems to be a good market for Philips test and measurement instruments and I am also a little surprised about the relative high prices. But then, they are usually easily repaired and work stable.
These two PM6667 are now almost 30 years old and still work good.
I am not sure that my Agilent 53220A will last 30 years, I have my doubt.
Offline G0HZU
« Reply #22 on: May 05, 2015, 04:25:38 pm »
There's certainly a lot to be said for the benefits of stable operation. In my youth I used to repair lots of ham/CB gear and it isn't always easy to get a stable reading from some makes/models of counter when probing a low level signal inside a radio. Back in those days I had access to many models of counter and the best of the lot was my old Marconi TF2430 which probably dates back the the early 1970s. It isn't a reciprocal counter but this is to its advantage in terms of radio servicing IMO.
Like your 6667 it only has a 7 digit display but it gives the most stable display of any counter I have ever used. This is all the more remarkable for it having no user controls for input level or triggering/filtering.
I still have it here today and there is no other counter on the planet I would rather use if I had to align a typical CB/HF ham radio today. Brilliant, clear LED display, very little drift in the standard oscillator and a really simple user interface. They need to be treated with some sympathy however as the thermal management of these counters is poor. So it has to be placed somewhere cool and also propped up to allow the lower vents to breathe. Otherwise the regulator at the back gets very hot and this is a common point of failure.
The standard oscillator inside is also much better than the one in my Philips PM6669. Much less drift during warmup and much more stable once warm. It could normally be used straight away as long as the room temperature was 'comfy' as it was rarely more than 7Hz away from 10MHz and usually got within 1-2Hz after a short warmup.
The only user controls on it are the three pushbuttons for gate time/resolution.
i.e. 10Hz or 1Hz or 0.1Hz resolution can be preset. It can display to 10Hz several times a second or to 1Hz in 1 second or to 0.1Hz in 10 seconds. Obviously, it often overflows the display when this happens but it still displays the lower 7 digits and it can do this up to 150MHz (despite only being branded as an 80MHz counter)
« Last Edit: May 05, 2015, 04:58:30 pm by G0HZU »
Offline dom0
« Reply #23 on: May 05, 2015, 04:32:45 pm »
Reminds of adjusting a PM519x generator. You open the case and the offsets jump around 20-40 mV (easily). The manual for those generators even mentions an adjustment kit, consisting of covers with holes for all the adjustments (about two dozen), so you don't disturb the "thermal equilibrium" of all the discrete amplifier stages. What a PITA. It took me ten tries or so until I got the DC offset below +- 3 mV.
Offline dom0
« Reply #24 on: May 05, 2015, 04:35:47 pm »
I remember that someone linked me a circuit a while ago that was developed in the GDR in the mid 80s or so, a discrete input stage for a frequency counter. The System D of it was an automatic regulation of hysteresis (and I think amplification in some way) to achieve a stable 50:50 duty cycle at the output. Settled for a different circuit in the end, but that one would probably given equally good or better results (at a higher parts count, though).
