Author Topic: Rohde & Schwarz CMU200  (Read 116957 times)
Offline _Wim_
Re: Rohde & Schwarz CMU200
« Reply #100 on: June 19, 2017, 05:47:28 am »
For measuring the frequency responce, you also can use the FreRes software (https://www.rohde-schwarz.com/uk/applications/freres-program-for-frequency-response-measurements-application-note_56280-15551.html) where the generator and analyser are configured for as many frequency points as you want. You can get a very high resolution read-out, but that takes a long time. But still, very usefull.
The following users thanked this post: casinada
Offline usagi
« Reply #101 on: June 19, 2017, 10:46:14 am »
i love my cmu200, the only downsides are no preamplifier option, and it only goes down to 10mhz.
it has a great signal generator, and with freeres i even have a poor man's tracking generator.
for what i paid for it, it's a phenomenal value.
Offline CJay
« Reply #102 on: June 19, 2017, 12:30:09 pm »
I'm rather keen on mine too, I've been tinkering with using one of the RF generator outputs as a LO for an external ADE-1 mixer, yet to quantify results but it seems to work.
I am having problems getting results from FreeRes though, I'd be grateful for any tips on configuration of the CMU and PC?
Offline Brainbox
« Reply #103 on: June 19, 2017, 05:30:06 pm »
I have both the tracking generator and the noise generator.
From those I prefer the tracking generator for its broader band.
The noise generator only have a satisfaction output in a small band.
Higher the bandwidth  decrease the output level ans also the resolution.
But it can be useful for preselection purpose.
FreRes also is a great solution but requires the use of a external PC.
I, who know nothing
Offline Octane
« Reply #104 on: June 20, 2017, 02:29:24 am »
I'm looking into buying a CMU200. But I'd like to know a few things.
Can the built in generator do FM, AM, or any other analog modulation types?
Can any of the analog modulation types be analyzed/demodulates?
I tried to find general info on the CMU200, but I could only find documentation on for example how to do GSM measurements.
No general manual or any other information.
Thanks,
Michael
« Last Edit: June 20, 2017, 03:06:37 pm by Octane »
W4MFT
Offline Brainbox
« Reply #105 on: June 20, 2017, 03:55:27 pm »
Yes it can do most types of modulation for measuring purposes.
Do a search at Google for the user manual and service manual, you will find all the specs You need.
I, who know nothing
The following users thanked this post: Octane
Offline Octane
« Reply #106 on: June 20, 2017, 04:56:42 pm »
Thanks Brainbox,
That's what I wanted to know. And yes I googled for the manuals, but I was not lucky yet. I'll keep trying!
BR,
Michael
W4MFT
Offline usagi
« Reply #107 on: June 21, 2017, 07:55:25 am »
yes, it can do FM, AM, SSB, DSB, CW
yes, but you have to get a cmu200 with the correct options.
Offline ps
« Reply #108 on: June 23, 2017, 09:29:20 pm »
One question concerning RF ports 1 and 2: these can be input and output at the same time.
Is there a directional coupler present, i.e if I use the signal generator to drive an antenna, do I measure the returned power (S11)?  Or does it just measure the voltage and calculates some kind of equivalent power assuming a 50 Ohm load?
This is not clear from the block diagram in the service manual.
Thank you, best regards
Patrick
Offline Octane
« Reply #109 on: June 24, 2017, 01:50:50 pm »
As far as I understand this it is either/or not and. There is no directional coupler inside. Please correct me if I'm wrong.
Michael
W4MFT
Offline usagi
« Reply #110 on: June 24, 2017, 09:39:56 pm »
cmu200 has no directional coupler.
took me a while to figure out how to do RL with freeres. if i remember you have to use RF3 out with RF1 in.
Offline Ringmodulator
« Reply #111 on: June 25, 2017, 03:03:45 pm »
for my understanding, the CMU-B95 ADDITIONAL RF GENERATOR limits the max RF input to 2W.
 Is it sufficient to remove this unit, to be able to use the full RF input of 50W, or do I need some kind of "jumper cable" to bridge the connections of the removed board?
Chris
Offline RF_fanatic
« Reply #112 on: June 25, 2017, 08:59:40 pm »
Yes, use AMPS option of the CMU and the audio output which can be attached to any audio input of a normal amplifier and you can use it as tuner (fm demodulated)
Offline cmu2017
« Reply #113 on: December 08, 2017, 12:23:41 pm »
I would place my tracing generator into the CMU. So does anyone know if there is somewhere 12v inside available? And it would be nice if this 12v can be switch on and off by one of the (function) keys on the front.
Does anyone know if this is possible?
The following users thanked this post: Yansi
Offline Qw3rtzuiop
« Reply #114 on: December 08, 2017, 12:29:38 pm »
There are two 12V rails inside. One is always present (12V standy). The other rail is available on power up. Afaik there is no switchable rail.
Offline cmu2017
« Reply #115 on: December 08, 2017, 02:55:32 pm »
Too bad that there is no switchable 12v. Have you maybe a photo or something else to see where I can find that 12v?
Offline Qw3rtzuiop
« Reply #116 on: December 08, 2017, 03:52:42 pm »
You can take a look at the service manual. There are the connector descriptions. The 12V should be present at almost any of the big connectors at the main pcb.
Edit:
Here is the spare parts list with the connector descriptions:
http://www3.rohde-schwarz.com/www/FileTranCS.nsf/4073a08b63359686c1256ae6002f8239/0b37697a081fa22ec1257834002005ed/$FILE/Shb-inst_Documents.pdf
Its not in the service manual.
« Last Edit: December 08, 2017, 04:03:05 pm by Qw3rtzuiop »
The following users thanked this post: _Wim_, cmu2017
Offline cmu2017
« Reply #117 on: December 09, 2017, 08:46:02 am »
Thanks, I found it.
Offline cmu2017
« Reply #118 on: December 22, 2017, 10:37:28 am »
Does anyone have the print design of the motherboard? I want to cut some small part of the corner. So I can place a new rivet nut for the leg. But I need to be sure there is no circuit on that place. (See image)
Offline cmu2017
« Reply #119 on: March 23, 2018, 07:39:04 am »
I’m using the cmu200 now for a while and I have a few questions about it which I couldn’t find on the manual.
- Is it possible to set a ref -> pk  to a negative peak
- Can I change the power measure form dbm to watt
- Is it possible to make a print screen save it a usb stick
Offline PartialDischarge
« Reply #120 on: March 23, 2018, 10:14:26 am »
In my CRTU I bought a PCMCIA to SD adapter to make screen dumps, but all attempts with different card sizes have been unsuccessful, although someone told me it worked in his unit.
Offline capt bullshot
« Reply #121 on: March 23, 2018, 10:42:32 am »
I did successfully install additional FW modules on my CMU200 (old CPU board w/o USB) using a PCMCIA to CF adaptor.
Never investigated how to make screenshots onto this CF card, would be interesting to get some hints ...
What I'm really looking for would be some simple linux software that connects via RS232 / GPIB to the CMU200 and takes the screenshot by running a simple binary on the PC - hardcore command line style, no clickety GUI.
Offline cmu2017
« Reply #122 on: March 23, 2018, 11:39:04 am »
What button’s do you use to make screencopy and how get it to the PCMCIA card? And are running for this on dos or windows. I’m using the dos modus.
« Last Edit: March 23, 2018, 11:53:50 am by cmu2017 »
« Reply #123 on: March 23, 2018, 11:42:20 am »
PRINT IIRC, there was an option to change the destination of the print somewhere, either to the HDD or the external memory through pcmcia
Offline cmu2017
« Reply #124 on: March 23, 2018, 11:55:36 am »
Ok, thanks, I'm going to try this.
