Author Topic: Altium "nets wire <name> has multiple names" error/warning  (Read 517 times)
Offline dnparadiceTopic starter
    • Blatant Git projects promotion
Does any one know a way to get the compiler to report an error for nets with multiple names, but ignore when the other net name is a sheet entry? 2847538-0
Offline thm_w
  • Non-expert
The following users thanked this post: dnparadice
Re: Altium "nets wire <name> has multiple names" error/warning
« Reply #2 on: June 24, 2026, 11:17:44 pm »
https://www.reddit.com/r/Altium/comments/1nq5ax9/net_has_multiple_names_error_when_using_signal/
You can try turning off sheet entry naming net.
Yes, turning off "Allow Sheet Entries to Name Nets" does the trick. Thanks!
