The issue: On the schematic, parameters used to appear separately (Value, Voltage, Package, Tolerance)(Screenshot 1), but after PLM integration they are merged into one long string. This makes them overlap and hard to read.(Screenshot 2)
From what I understand, the actual PLM integration mapping (Altium params → ENOVIA attributes) is only in the Workspace Admin (browser) → Settings → PLM Integration, or via XML if on Server.
Can anyone confirm if that’s correct, and share docs/examples for setting up the ENOVIA connector mapping so schematic parameters stay split as before?
Or is there any Altium Delphi script for this where i cant split the parameters. kindly help
