I built my 555 monostable circuit on my breadboard and it worked perfectly. I even scoped the trigger and watched C1 charge and discharge and I had a nice LED to show the output (thanks for the help in my other post guys!). I moved it to my prototype board and soldered everything in place, with the exception of the LED because now I will need it to control a relay instead. But before I went any further, I thought I would check things out. It's a good thing I did because now it seems that C1 isn't discharging when the time delay is up. I remember when it was on the breadboard that C1 would slowly start charging after triggering and when it gets to the right point (2/3rd VCC???), the time delay would end and C1 would discharge immediately. But now I don't see C1 discharging at the end of the time delay. It just seems to charge and charge and charge.
I do see the pushbutton correctly in the trace on the scope, so I don't think that is the problem. From the symptoms, it would almost seem that the circuit thinks it is in a constant trigger.
I'm at work now, so I don't have the circuit in front of me. And I didn't think to just test pin 3 (output).
But I was wondering, could it be that the C1 won't discharge unless something is connected to the output? Right now I have nothing connected to pin 3. Or is it more likely that I gooned something up when soldering everything in place?
