I understand the issue with diodes in parallel not sharing current properly, especially when they are separate components. But in the case of this D3SB60 bridge, I believe the situation might be a bit different, since the diode chips are all mounted in the same block, very close to each other and running at almost the same temperature. That leads me to think their behavior tends to be more similar, which should reduce the usual imbalance that happens with discrete diodes. For that reason, I ended up choosing to make use of D2 and D4 as well. Since they’re already part of the same module, I assume it makes more sense to use the whole bridge instead of leaving two diodes unused in the doubler mode.
Still, I’ll take into account the point you raised about adding another component that could become a failure point. That’s definitely something to weigh in the decision.
