Hello, I have a Makita GA5030R (125 mm, 720 W) angle grinder and I wanted to built a speed controller. I built the attached schematic, but as I am lowering the speed, appears a buzzing sound from the controller.
I have the following questions:
1. It is safe to use a dimmer to control the rpm of an angle grinder ?
2. Can this buzzing sound be removed ?
3. Can you please recommend a better schematic ?
The angle grinder will be used for grinding wood, using an Velcro adapter and 125 mm diameter sand paper.
Thank you in advance.
