You were reading from it, not writing to it, it read ok then it went away, there is no reason that the fuses should have changed.
0x00 (fuses, signature) is indicative of a complete failure to communicate.
If it was me, what I would be looking at is a lot more fundamental than a fuse or clock issue. Check your wiring, voltages, and reset.
