Author Topic: C556 and C546 transistor  (Read 4025 times)
Offline jmctechTopic starter
« on: February 27, 2018, 02:57:43 am »
Hello,
I have been tasked with trouble shooting a board for a obsolete machine, the board controls a couple of motors, looks like current limiting resistors for the motors failed short and over loaded the main transistors (bvd64b & bvd67A) and these transistors pictured which were hooked to the base of the main transistors. My question is, I was able to find c546 transistors in a cross reference, but all I can find for the 556 is BC556. I have not been able to find any info on a c556. Are these BC### and the B is just not on the case? Or are they different?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Offline amspire
Re: C556 and C546 transistor
« Reply #1 on: February 27, 2018, 03:03:03 am »
It is the BC546 (NPN general purpose) and BC556 (PNP general purpose) transistors. Originally designed by Philips.
« Reply #2 on: February 27, 2018, 05:20:56 am »
Thank you
Offline Peabody
« Reply #3 on: February 27, 2018, 06:17:23 am »
Could be 2SC546 and 2SC556.
Offline amspire
« Reply #4 on: February 27, 2018, 06:30:31 am »
They are Philips BC546/556. I have a some Philips BC557B transistors with the silvered front and the same PH code.
