Author Topic: Can’t find correct pot value  (Read 2126 times)
Offline jeffjmrTopic starter
« on: March 16, 2022, 04:18:46 pm »
I’d like some finer control over my benchtop PS current output. I replaced the voltage pot with a precision 10 turn unit and it is working great.  I’d like to do the same on the current side.
But my unit calls for a 3K pot and I can’t find a multi-turn pot in that value. But I can find a 5K pot.
So, am I correct in assuming I can place a 7500 ohm resistor across pins 2 and 3 on the 5K pot to end up functionally at 0 to 3K?
Thank,
Jeff
« Last Edit: March 16, 2022, 04:20:58 pm by jeffjmr »
Online TimFox
Re: Can’t find correct pot value
« Reply #1 on: March 16, 2022, 04:31:59 pm »
Please show the entire potentiometer circuit.
If there is no resistor in series with the existing pot, but the 3k resistance makes a difference to the current sense, then your solution of 7500 ohms in parallel with a 5000 ohm replacement pot will work well.
If there is no resistor in series with the pot, and the 3k resistance is not important across the current sense resistor, then your parallel resistor is probably not needed.
Offline Terry Bites
Offline bob91343
« Reply #3 on: March 16, 2022, 04:54:57 pm »
Those are not 10 turns.
Offline Terry Bites
« Reply #4 on: March 16, 2022, 05:03:07 pm »
did you check them all in one minute- fantastic
Online TimFox
« Reply #5 on: March 16, 2022, 05:09:07 pm »
I checked the first page of results, all of which are single-turn, in less than a minute from your link, even with the typo.
Similarly when adding "10-turn" to the search:  Google goes to results for either "3k" or "10 turn".
Offline Vovk_Z
  • Country: ua
« Reply #6 on: March 16, 2022, 05:29:13 pm »
I usually redesign a circuit to have a possibility to use 2k or 5k pots.
Online TimFox
« Reply #7 on: March 16, 2022, 05:32:40 pm »
Similarly, when dealing with multi-turn trimpots, I find that the standard values are 10, 20, 50, 100, 200, 500, ... , 20k, 50k.
Offline golden_labels
« Reply #8 on: March 16, 2022, 08:34:32 pm »
Perhaps wait for OP to post the circuit? Depending on what’s the role and placement of the potentiometer, its exact value may be not important.
While posting links to dynamically generated results, be aware that what others see may significantly differ from what you saw. That is in particular true for heavily profiled results like those from Goofle.
Why 📎 | We live in times when half of people have IQ below 100.
Online TimFox
« Reply #9 on: March 16, 2022, 09:07:53 pm »
That's what I said in Reply #1, where I asked about the pot circuit.
« Reply #10 on: March 16, 2022, 11:23:46 pm »
And that’s what I am referring to.
Offline themadhippy
« Reply #11 on: March 17, 2022, 12:32:52 am »
Buy a 3k pot and add a reduction drive
« Reply #12 on: March 17, 2022, 02:23:28 am »
It doesn’t have to be a 10 turn. A 3 or 5 turn precision pot would still be an improvement over the 300 degree originals. I searched pretty well and could not find any multi-turn at 3K.
It’s for my Leader LPS-152, a surprisingly stable PS on both voltage and current, but the 3k pot adjustments are just too coarse sometimes.
There are three altogether, +1A and -1A on the 25v side and +5A on the 6v side, schematic sections for two are attached below, near the rectangular “Current” boxes.  I have a 10 turn 10K on the 25v side, and a 5 turn 10k on the 6v side.
Thanks all for your responses. I see no reason the 7500 ohm resistor in parallel shouldn’t work.
Jeff
Online Ian.M
« Reply #13 on: March 17, 2022, 03:49:41 am »
The current pot is picking off a voltage from a potential divider for the OPAMP, which has very high input impedance so the load on its wiper is negligible.  Therefore your original assumption:
is correct, for this circuit.
If there had been significant load on the wiper or if it had been wired as a two terminal rheostat, then a parallel resistor would have resulted in a highly undesirable change in the 'law' of the pot, from linear to something else (non-linear), determined by the circuit.
« Last Edit: March 17, 2022, 03:54:15 am by Ian.M »
The following users thanked this post: jeffjmr
Offline bob91343
« Reply #14 on: March 17, 2022, 06:09:39 am »
The 150 Ohm and 62k resistors in series with the 3k pot can be increased or decreased proportionately to allow use of a standard pot.  To use a 2k pot for instance, lower the two resistors by one-third to 100 Ohms and 39k Ohms and you should be good to go.  To use a 5k pot, increase the two to 250 and 110k Ohms.
The following users thanked this post: tooki, jeffjmr
« Reply #15 on: March 17, 2022, 11:39:10 am »
I see how that would work. But I think it would be easier and less invasive to parallel one 7500 ohm onto the pot as opposed to changing out two on the PCB, provided I get the same result.
But I appreciate your pointing that out. I did not study the schematic closely enough to think of that alternative solution.
Jeff
