So, am I correct in assuming I can place a 7500 ohm resistor across pins 2 and 3 on the 5K pot to end up functionally at 0 to 3K?
The 150 Ohm and 62k resistors in series with the 3k pot can be increased or decreased proportionately to allow use of a standard pot. To use a 2k pot for instance, lower the two resistors by one-third to 100 Ohms and 39k Ohms and you should be good to go. To use a 5k pot, increase the two to 250 and 110k Ohms.
