Author Topic: clap circuit  (Read 18210 times)
Offline electronics technicianTopic starter
clap circuit
« on: March 06, 2014, 01:05:54 am »
i need help with this circuit please
 http://circuiteasy.com/clap-switch/
i got 2n3904 replacement transistor for all the bc transistors they are all npn that i got i made it on a solderless breadboard and the circuit was not working
i need help before saturday  i appreciate all the help
Online dr.diesel
Re: clap circuit
« Reply #1 on: March 06, 2014, 01:13:47 am »
What happens on Saturday?
Re: clap circuit
« Reply #2 on: March 06, 2014, 01:17:21 am »
i will submit it in class to get  graded on it i dont want to fail just because it was not working
Online dr.diesel
Re: clap circuit
« Reply #3 on: March 06, 2014, 01:21:11 am »
What will you learn if I give you the answer?
Re: clap circuit
« Reply #4 on: March 06, 2014, 01:23:51 am »
 |O
im frustrated with this circuit i have been on this for almost a month now trying different combinations of pinouts and still no working project
Offline minibutmany
Re: clap circuit
« Reply #5 on: March 06, 2014, 01:46:53 am »
This doesn't really look like the best circuit to be poking around in if you don't have experience with mains.
Offline Nerull
Re: clap circuit
« Reply #6 on: March 06, 2014, 01:54:16 am »
120VAC is lethal. It can and will kill you if you aren't careful.
Re: clap circuit
« Reply #7 on: March 06, 2014, 01:56:26 am »
thats not the point i need help with this clap circuit please help btw
« Last Edit: March 06, 2014, 02:12:06 am by electronics technician »
Offline c4757p
  • adieu
Re: clap circuit
« Reply #8 on: March 06, 2014, 02:01:28 am »
The circuit will work fine off mains too - please move off the mains to test this further.
Take a photo so we can see what's wrong.
Offline Nerull
Re: clap circuit
« Reply #9 on: March 06, 2014, 02:02:47 am »
It is exactly the point. You are playing with a circuit you don't understand, with dangers you don't understand. That is, to put it mildly, incredibly stupid. Your teacher should fail you for that, to discourage other students from putting themselves in danger.
And please, for the love of god, tell me you aren't routing 120VAC through a breadboard.  |O
Pick a project less likely to get you killed, your parents and teachers will appreciate it.
Re: clap circuit
« Reply #10 on: March 06, 2014, 02:10:06 am »
you dont understand its my teacher that gave my class this project to do but im having problems with getting it working can you help
i was never going to run 120v ac though a bread board
« Last Edit: March 06, 2014, 02:15:33 am by electronics technician »
Offline kizzap
Re: clap circuit
« Reply #11 on: March 06, 2014, 02:15:39 am »
Things: people around here don't like people playing with mains if they don't know what they are doing. 120V mains, while lower then other country's mains voltages, is still lethal.
That said, from the schematic, the mains looks like it could be completely isolated from any breadboards. Please ensure you fuse mains.
You also need to tell us what tools you have at your disposal.
What I would suggest doing, is to break the circuit down into blocks on your breadboard, (and start off not having it powered from mains) first thing I would get working is the microphone input. If you have a scope, try see if you can trigger off the collector of Q1, to ensure that side of the circuit is working, then add in additional parts to the circuit.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Re: clap circuit
« Reply #12 on: March 06, 2014, 02:19:37 am »
i dont have a scope yet unfortunately but i have a dmm and everything i need to solder it to a perf-board
Offline kizzap
Re: clap circuit
« Reply #13 on: March 06, 2014, 02:53:26 am »
does the meter have a min/max mode?
Re: clap circuit
« Reply #14 on: March 06, 2014, 03:03:55 am »
http://www.transcat.com/catalog/productdetail.aspx?itemnum=DM-210
this is the one i have thinking about switching to fluke next time
Offline LektroiD
  • If it didn't explode, I'm happy.
    • Music here
Re: clap circuit
« Reply #15 on: March 06, 2014, 03:20:25 am »
2n3904's are different pinout to BC's. Check the datasheets.
Re: clap circuit
« Reply #16 on: March 06, 2014, 03:30:29 am »
the pinout of the 2n3904 is EBC correct me if im wrong
Offline LektroiD
    • Music here
Re: clap circuit
« Reply #17 on: March 06, 2014, 03:36:39 am »
depends which way you look at it (check the datasheets for both). What's the BC you're substituting?
Re: clap circuit
« Reply #18 on: March 06, 2014, 03:52:57 am »
with the flat side facing you it was EBC but like you said it depends on how you look at it
i got this replacement for all the bc548 and bc368
so i have 4 2n3904 npn trannies
Offline kizzap
Re: clap circuit
« Reply #19 on: March 06, 2014, 04:01:36 am »
You realise that different transistors have different gains right? so the circuit won't function as intended with the wrong transistors, without recalculating the biasing on each of the transistors.
Offline vk6zgo
Re: clap circuit
« Reply #20 on: March 06, 2014, 04:03:02 am »
I would second the suggestion----
This isn't really a high frequency circuit,so you should be able to check the Bistable & the other stuff with any old DMM.
The only place you may have problems is with the mic circuit,because the pulse caused by  the "clap" is only of short duration.
The circuit operation description on the website is pretty lousy,& I can maybe do better,so here goes!
Assume initially,that Q3 of the Bistable multivibrator (flip-flop) Q2,Q3 is turned "on"hard (saturated),so its collector voltage is very low,approaching zero volts
At the same time Q2 is "cut off", so its collector voltage is very high,approximately at the positive supply voltage.,
Q3 collector is connected to Q4 base via D4 & R13,& Q4 is "cut off"so the relay is not operated.
If the Bistable M/V changes state,Q2 is now "saturated",& Q3 is cutoff.
Q3's collector goes high.turning Q4 "on",& operating the relay.
So far,so good!
How do we make the Bistable M/V change state?
The mic "hears" the "clap" generating an ac signal at the base of Q1.
The amplified signal from Q1 is then fed to Q2,Q3,bases via C3,D2,& C4 ,D3.
The diodes only pass the negative half cycle of the signal,presenting the bases with negative pulses
which momentarily overcome the existing positive bias on the "saturated" transistor,(in this case,Q3) & turn it "off".
Q3'scollector goes "high",biasing Q2 "on".
PS: I wouldn't panic much ,as far as the transistor types for the Bistable & relay driver are concerned,but Q1 is an amplifier.
If it has insufficient voltage gain,its output may not be sufficient to trigger the Bistable into changing state.
Another point is to get a mic which has a fairly high output voltage.
Apparently they used an Electret mic,as they have an FET preamp built in,hence.R1.
« Last Edit: March 06, 2014, 04:20:12 am by vk6zgo »
Re: clap circuit
« Reply #21 on: March 06, 2014, 04:08:43 am »
how do i go about calculating the biasing of the transistors
So far,so good!
i know how the circuit works  thanks for the explaination it helped
 the problem is getting it to work
Offline vk6zgo
Re: clap circuit
« Reply #22 on: March 06, 2014, 04:31:06 am »
Sometimes it helps to trouble shoot the problem if you revise the operating principles.
You could maybe,insert a negative voltage at the junction of C3,C4 & see if your Bistable changes state.
What state is the Bistable in when you first turn it on?
What state is Q4?
You can see if Q4 turns on & off by connecting its base to + supply via a 5k or so resistor.
Try placing your finger on the base of Q1.--------Induced Mains hum may be enough to trigger the Bistable.
Offline vk6zgo
Re: clap circuit
« Reply #23 on: March 06, 2014, 05:16:43 am »
There are some tips on biasing,etc on this site:
http://www.rason.org/Projects/bipolamp/bipolamp.htm
Another place to look is the E-Book at All about Circuits.
Offline AndyC_772
Re: clap circuit
« Reply #24 on: March 06, 2014, 06:40:06 am »
|O
To get this sorted, you're going to have a very long, careful and methodical troubleshooting session. Make some coffee, you'll be needing it.
Type the part numbers for the transistors you have into Google, find the data sheets, and check the pinouts. There is no short cut or substitute for this. Assume nothing.
If you can, remove the transistors from your board and replace them with brand new ones, correctly connected. This will help ensure you're not wasting time trying to build a circuit with parts which have been damaged by incorrect use.
Go round your circuit with a multimeter, and check what voltage exists at every point.
EVERY point.
When you have that information, post up a clearly annotated schematic, and maybe someone will be able to give you some pointers as to where faults exist, or some further experiments to try. A detailed, methodical analysis will look good in your report even if the circuit never works, so this is anything but wasted effort even if nobody replies at all.
Post a photo of your board. Make sure it's clear, sharp, and has good lighting.
Without a crystal clear picture of what your board looks like and what voltages exist where, it's impossible to debug it remotely.
