Author Topic: Dumb Ass with a scope  (Read 13876 times)
Offline easilyconfusedTopic starter
« on: July 29, 2010, 03:27:17 am »
I took Dave's advice and bought an old analog scope. It' an Iwatsu SS-5710. I have no business with a scope being the t-total beginner that I am. But I convinced myself it would help me to understand things better if I connected it to my Radio Shack Electronics Learning Lab experiments. The guy wanted a $100. I offered half that. He declined so I walked. Then I went back and gave him the hundred. Anyhow it seems to be out of cal. The PDF I found says the calibration lug should output 0.3v and this one only shows 0.15v. I've tried many settings and get the same result. The time axis is out as well. I looked under the hood but didn't dare touch anything. I'm mindful that there's lots of voltage in there even when unplugged. I didn't see anything that made me feel confident about twisting them. There were a dozen or so trimmers (I guess that's what you call them), but none of them said Y adjust or X adjust so I put it back together. Can anyone suggest how to calibrate it. I doubt if I can afford to have it done professionally.
Offline ThunderSqueak
  • Dont be a freak... dont be a freak... dont be a ..
    • ThunderSqueak!
Re: Dumb Ass with a scope
« Reply #1 on: July 29, 2010, 03:31:58 am »
Take a good picture of it on so we can read everything while you are testing the calibration... just curious on how you have it setup while you are testing calibration.
Currently working with non-binary computing, no reason for it... just doing because I can ^^
« Reply #2 on: July 29, 2010, 03:56:08 am »
In this pic my settings are 50mV/0.2mSEC. I'm attached to the calibration lug and the probe is switched to the X10 scale. The PDF file calls for 0.3v and it looks to me like I have half that. I hope I'm looking at it wrong.
Offline EEVblog
« Reply #3 on: July 29, 2010, 04:07:41 am »
That looks like 300mV to me!
6 divisions of 50mV
Freq looks pretty close to 1KHz, just a bit off. But this could be the calibrator and not the scope.
Dave
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: July 29, 2010, 04:21:15 am »
That was probably 0.3Vpp.
Offline DJPhil
« Reply #5 on: July 29, 2010, 05:13:52 am »
I picked up an old Tek 465B a while back, and the cal on it is a bit slow, a bit low, and quite noisy. The scope itself performs well, and casual use at <1MHz hasn't unearthed any significant problems. I'm pretty sure it's just the calibrator is just showing it's age a bit in both our scopes.
If you're just getting started I recommend reading through Tek's updated XYZ's of Oscilloscopes. It's a quick read and one of the best all purpose introductions I've seen. With that handy, you can begin to put it through it's paces if you have or can build a signal source or two.
Hope that helps. :)
Offline EEVblog
« Reply #6 on: July 29, 2010, 05:29:48 am »
Yeah, scope cal outputs are always rated in peak-peak voltage.
Dave.
    • ThunderSqueak!
« Reply #7 on: July 29, 2010, 05:30:35 am »
6 divisions of 50mV
Dave
What Dave said :P
Which is why I asked for a picture, was curious how you were reading it.  :D
« Reply #8 on: July 29, 2010, 05:38:25 am »
6 divisions of 50mV
Dave
Obviously my logic is screwed up. My thinking was as follows. My dial is set on 50mV. I have six large squares with 5 divisions each or a total of 30 divisions. I multiplied the 30 divisions by 50mV (each division) for a total of 1500mV. I divided that by 1000 to reduce the millivolts to volts. The number is 1.5 volts. Then I divided that by the X10 (the probe setting) to reduce the number to a 1:1 result which is 0.15volts. I went to bed after posting the pic. I couldn't sleep. Then I had one of those revelations where you sit up and slam your palm into your forehead and say to yourself "Why don't you check the voltage on the lug to see what it is instead of what it's supposed to be (based on the PDF)". So I got up, came in here and checked the lug with my new Fluke 17B (which I also don't deserve). The voltage was 1.48. So doesn't that support my logic? Or not? As to the timing-- I don't know how to check that with my Fluke. It does have a Hz% button. But when I press it (while in the DCV mode) it simply shows 0.000.
« Last Edit: July 29, 2010, 05:40:38 am by easilyconfused »
« Reply #9 on: July 29, 2010, 05:59:22 am »
I guess I've pretty well exhausted this thread. But I think the conclusion is that the voltage on the scope is consistent with the multimeter voltage on the lug. And-- the timing is correct IF the lug is actually pulsating at 1KHz (which I have not verified 'cause I don't know how).
And-- with regard to the voltage-- I really don't care how many volts are coming out of the lug as long as the scope reflects that voltage. I hope my reasoning is correct. Thanks for all responses. I really do appreciate it. I know I really don't belong on a forum mainly populated with advanced practitioners. I will take a look at the XYZ PDF. I've been there before but it might mean more now since I've developed a little more understanding of scopes and how to interpret them.
Offline DJPhil
« Reply #10 on: July 29, 2010, 05:59:45 am »
You'll have to be in the ACV mode to read frequency. Switch to ACV, change range to get a good reading, and hit the Hz% once, and you should be good. Hitting the Hz% again will show you duty cycle, which should be very close to 50%.
Hope that helps. :)
« Reply #11 on: July 29, 2010, 06:06:35 am »
Hope that helps. :)
I did as you suggested. In the AC mode I got a voltage very similar to the DC mode (about 1 volt higher). I pressed the Hz% button and got zeros. I pressed it again and got zero percent.  ???
    • ThunderSqueak!
« Reply #12 on: July 29, 2010, 06:07:32 am »
Here, look at this, a cute little tutorial on how to read your scope  I think it will help :)
Oscilloscope AC Voltage Measurements
http://www.wisc-online.com/Objects/ViewObject.aspx?ID=ACE6803
Oscilloscope: DC Voltage Measurements
http://www.wisc-online.com/Objects/ViewObject.aspx?ID=ACE3403
Oscilloscope Frequency Measurements
http://www.wisc-online.com/objects/ViewObject.aspx?ID=ACE3503
Oscilloscope Coupling Switch
http://www.wisc-online.com/Objects/ViewObject.aspx?ID=ACE3603
Oscilloscope Phase Shift Measurements
http://www.wisc-online.com/Objects/ViewObject.aspx?ID=ACE3803
seriously.... go through each one  >:(
« Last Edit: July 29, 2010, 06:09:59 am by ThunderSqueak »
« Reply #13 on: July 29, 2010, 06:13:40 am »
I absolutely will. And thank you.
    • ThunderSqueak!
« Reply #14 on: July 29, 2010, 07:16:01 am »
Oh, something that might not be obvious in those tutorials, they want you to click on the controls sometimes during the tutorial and wont show the "next" button until you do so.    Keeps you on your toes  and out of "click next to get it over with" mode.
Offline EEVblog
« Reply #15 on: July 29, 2010, 08:03:15 am »
6 divisions of 50mV
Dave
You have the concept incorrect. Those "large squares" are the divisions. The smaller marks are not counted.
So your signal is 6 "divisions" high or 50mV * 6 = 300mV peak-to-peak. That's exactly what it should be.
You can't measure the peak-to-peak voltage of anything with a multimeter, it doesn't work like that. Meters are designed to measure either the average or true RMS value of a an AC waveform.
Dave.
Offline djsb
« Reply #16 on: July 29, 2010, 10:45:22 am »
Also each subdivision equals 10mv (50/5). So if the trace only goes part way across a full division you count the number of subdivisions and multiply by 10mv (at the 50mv per division setting). This is then added to the full division reading as above.
I've probably confused you even more now.
« Last Edit: July 29, 2010, 10:49:01 am by djsb »
Hertfordshire,UK
University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor. Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime. Credited Kicad French to English translator.
Offline squeezee
« Reply #17 on: July 29, 2010, 12:52:02 pm »
Sure you can, using the PEAK button if the meter has it.
(although the 17B doesn't)
« Last Edit: July 29, 2010, 12:54:11 pm by squeezee »
« Reply #18 on: July 29, 2010, 01:43:27 pm »
"You can't measure the peak-to-peak voltage of anything with a multimeter, it doesn't work like that. Meters are designed to measure either the average or true RMS value of a an AC waveform. Dave."
Okay. This is going to be one of those moments where this learner must take something on faith. I understand what you said about the hash marks, and I'm VERY pleased that my scope is apparently in cal in the X and the Y. But I hope it's not hard for the forum to understand how I would expect the lug to show a voltage on my mm to match the stated lug voltage (from the manual). And for the sake of expanding my knowledge I still want to learn why it doesn't. Thanks to all.
Offline DJPhil
« Reply #19 on: July 29, 2010, 02:17:11 pm »
Hope that helps. :)
Hmm, I'm a bit baffled too. I assume the probes are where they're supposed to be if you're getting an AC voltage reading, but just to be sure, you have one lead on scope ground and one lead on the cal bar? I'm also assuming the range switch doesn't need adjustment, I'm not sure.
It's possible that the 17 isn't sensitive enough to measure that weak a signal. All I can find online is the calibration guide, so I'm not sure what the actual specs are. The performance test on page 11 says to use a 1V signal to check frequency to 5KHz. I don't think it's very likely that this is the problem, but I can't be sure.
Sorry if I added to the confusion.  :-[
Offline MTron
  • General hobbyist - modding, electronics, audio
« Reply #20 on: July 29, 2010, 03:39:08 pm »
This is exactly the forum you should be on, and there are plenty of beginers here, like me for example. I just purchased my first oscilloscope as well, and your not alone in your confusion...there is quite a learning curve
as for your division confusion. 50mV per div means every large square is 50mV. Between each square are hash marks, if there are 5 between each large square then each hash is 1/5 x 50mV or 10mV.  Also keep in mind your probe x10 probes will output 1/10th the actual voltage. Your scope might have markings on the volts/div knob that display what the reading will be with a X1 or X10 probe.
Remember...ask questions...make mistakes....its the best way to learn.
Your friendly neighborhood.....Dental Student
 - Latest Project - SIPP EL84 Tube Amp
 - Computer building/modding, IT, and DIY electronics!
Offline djsb
« Reply #21 on: July 29, 2010, 03:39:52 pm »
The measurement should be done with the meter set to AC voltage otherwise any DC offset will also be measured. Some meters take this into account, others maybe not. This is why an oscilloscope is so useful as it allows you to see any DC offset present.
As an example on my Tek 2225 scopes 0.936Hz 0.52v Pk-Pk cal output my cheapo maplins precision gold multimeter reads 0.257V on ACV and my Gossen Metrohit x-tra reads 0.2479V true RMS. Both pretty close, but I trust the Gossen more. You should get around 150mv on your multimeter. RMS values also depends on the waveform. For a squarewave the RMS value is the same as the amplitude (peak value). For a sine wave the RMS is amplitude divided by the square root of 2 (or multiplied by 0.707).
All explained here.
http://en.wikipedia.org/wiki/Root_mean_square
David.
« Last Edit: July 29, 2010, 04:15:10 pm by djsb »
Hertfordshire,UK
alm
  • Guest
« Reply #22 on: July 29, 2010, 07:12:47 pm »
Tektronix has an appnote XYZs of Oscilloscopes that is helpful for beginners, not just for Tek scopes (most scopes work very similar).
« Reply #23 on: July 29, 2010, 10:23:36 pm »
No you haven't. I understand that. Thanks
« Reply #24 on: July 29, 2010, 10:28:42 pm »
Thanks bro
