Author Topic: Extremely simple USB-C power source  (Read 408 times)
Offline SaimounTopic starter
« on: May 17, 2024, 09:55:28 am »
Hi
Is it possible to have a simple USB Type-C port on the host/source side without a USB PD chip? (for example turning on/off Vbus with transistors)
All the port has to do is to transmit power, no data.
Thank you :)
Re: Extremely simple USB-C power source
« Reply #1 on: May 17, 2024, 10:44:21 am »
Would something like the attached circuit work for example?
I understand connecting the CC pins together breaks the standard - but since all USB-C cables only connect one of the two it should work?
Offline wasedadoc
« Reply #2 on: May 17, 2024, 11:08:36 am »
Why do you want/need to switch the power?  Just wire 5v and 0v to the appropriate pins of the socket?
Offline tszaboo
« Reply #3 on: May 17, 2024, 11:50:56 am »
You don't have to support power delivery for a Type-C port.
I think for a 5V device the only requirements are to have two pulldown resistors on the CC1/CC2, so if you have a simple "OR" detection on these two lines, you can control a current limited power switch with that. There are dedicated USB power controllers as well.
« Reply #4 on: May 18, 2024, 09:18:42 am »
If you do that and two hosts are plugged into each other them boom >:D
Turning on the Vbus only when a device is connected is part of the spec :)
