Evening, everyone! Been lurking around for a while, figured it was time to join in on the conversation! Looking forward to being a part of the community.
I'm not sure the beginners' section is the place for this, but I figure it's better safe than sorry. I'm a senior computer engineering student here at Penn State in PA; I've been working on a design project lately for a switch-mode power supply in my own time, but have basically run out of people here at the university to bother with it. The first design was actually used for an embedded systems class a couple weeks ago where I used a PIC18 MCU as an SMPS controller on a PCB hastily milled on our board router; aside from blowing out the switching FET from leaving out a freewheeling diode by accident, it worked reasonably well for something designed from the ground up in under one week. Even complied with modern medical equipment creepage/clearance/isolation requirements.
I've attached a quick schematic capture from DipTrace just for reference. Control unit is on the secondary; yes, it's about as basic as they come, but was made under a significant time crunch.
All that out of the way, I have a handful of questions about SMPS designs, particular the flyback topology, that nobody I've talked to seems to have a concise answer. I'll bullet them to avoid a wall of text.
- I have no clue how to spec that transformer on one of these. Answers I've gotten have ranged from 'you want a coupled inductor, not a transformer' to 'just calculate the magnetic field across the transformer's air gap', and I have no idea how any of these translate to a set of meaningful component values, or even the proper type of component to be using. I understand the concepts regarding finding the maximum Ton for a given inductance and getting switching frequencies from that, but none of the transformers used in an actual flyback converter are anywhere near what I was expecting, meaning I've obviously got something conceptually wrong.
- Regarding multi-phase flyback converters. Let's say I want to design a 120VAC to 12VDC power supply with four flyback phases; in my own design, I'd have 170VDC rectified directly from the mains, and then four independent coils switched such that their phase alignment will allow for massively reduced ripple at greater currents. Now, I was told this is a bad idea in that the same load-balancing issues with trying to parallel multiple linear regulators will be present with multiple switched coils, which doesn't sound quite right to me. Can anyone clarify?
Those are really the two biggest points; any helpful insight would be appreciated! I'm up here over the summer due to possibly picking up an unexpected double major in electrical engineering, and so I pretty much have free reign of the PCB mill.
Looking forward to it! EDIT: Just realized that's the old schematic without the freewheeler and a few other things. Oh well, you get the idea.
