Author Topic: FREE Analog Engineer's Circuit Cookbooks from Texas Instruments  (Read 14454 times)
Offline Lee LeducTopic starter
Thought I'd pass this along to the group. Free books from TI.
Analog-to-Digital Converters (ADCs)
Operational Amplifiers (Op Amps)
http://www.ti.com/analog-circuit/circuit-cookbook.html?HQS=asc-null-null-tlamps_cookbook-asset-lp-null-wwe&DCM=yes
Offline Sudo_apt-get_install_yum
Re: FREE Analog Engineer's Circuit Cookbooks from Texas Instruments
« Reply #1 on: June 19, 2018, 12:12:19 pm »
Had a friend surprise me this morning with a copy of each printed out!
I already know most of this but it’s a nice refresher, I haven’t done much analog work lately
The following users thanked this post: kd7eir
Offline MasterT
« Reply #2 on: June 19, 2018, 01:45:33 pm »
Circuit Cookbook: ADC's, p.10 & p.16 resistor 200 kOhm seems very high for SAR ADC. Brief search in the ads7042 data sheet shows correct value, p.25 - 200 Ohm.
Offline Audioguru
« Reply #3 on: June 20, 2018, 01:47:29 am »
When I clicked on "download" it opened but did not copy it. I needed to find the cookbook in Google to find a link that I could copy the PDF file.
Online Gyro
« Reply #4 on: June 20, 2018, 08:54:46 am »
A most useful little book on that page is the "The Signal" free ebook, down on the second row. It covers, in an easily accessible form, so many of the opamp questions I've seen in this section.
http://www.ti.com/lit/slyt701
Best Regards, Chris
Offline ArthurKay
« Reply #5 on: June 21, 2018, 08:20:48 pm »
Just a quick comment on the cookbook circuit.  The value of that filter resistor should be different depending on the sampling rate of the converter and the amplifier used.  This circuit example is for a very low power system, so the sampling rate is very low.  When the sampling rate is low, the time to charge the internal sample and hold capacitor is long and a larger time constant can be used.  Also, for a low power amplifier (like the one in the circuit) a large series resistor may be required for stability.  In any case, the transient analysis simulation (page 14) shows that the circuit settles well.  The link below is to a video series that shows how to select the RC circuit and confirm the accuracy using simulation.
https://training.ti.com/ti-precision-labs-adcs
Offline MasterT
« Reply #6 on: June 21, 2018, 09:01:22 pm »
Title says 1-ksps on p.10, and for this specific sampling rate error is very big:
C, pF   F, Hz   R, Ohm                R-lpf           Error, %
15          1000     10610329.5       200000   1.85008236122648
where C - capacitance S/H, and error is calculated as two resistors voltage divider. To get 1/2 LSB sampling rate has to be less than 5 sps.
Online flash2b
  • Everything I like about myself is better with you.
« Last Edit: June 21, 2018, 10:36:40 pm by flash2b »
They say attention is a shovel. It's time to dig 'em out.
Offline ohmjke
« Reply #8 on: October 10, 2025, 08:06:05 pm »
Direct links without registration or account:
https://www.ti.com/seclit/sl/slyy138/slyy138.pdf
https://www.ti.com/seclit/sl/slyy137/slyy137.pdf
http://www.ti.com/lit/ml/slyt701/slyt701.pdf
https://fizyka.umk.pl/~slawg/prukan/slyw038b-TIanalog-ebook.pdf
Links are unavailable w/o registration.
I have an account on ti.com, but now (many years later) I can't login using it...
Can someone please download this two books and post them here?
"Analog Engineer’s Circuit Cookbook: Amplifiers" and "Analog Engineer’s Circuit Cookbook: Data Converters" at the end of this page:
https://www.ti.com/design-development/analog-circuits.html?HQS=asc-null-null-tlamps_cookbook-asset-lp-null-wwe&DCM=yes
Online flash2b
« Reply #10 on: October 11, 2025, 07:19:22 am »
They must have changed the access since previously all my links worked without having an account.
Offline ohmjke
« Reply #11 on: October 12, 2025, 11:17:53 am »
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/908/TI_2D00_Analog-Engineers-circuit-cook-book-slyy138.pdf
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/14/CircuitCookbook_2D00_OpAmps.pdf
@amyk, thank you. But I'm not sure it's latest version of the books. At least the one with "slyy138" in URL.
On preview (see my link or attached image above) covers are dark, and second book calls "Data converters", not just "ADCs".
Did you really open page with my link (and click "View e-book") or have just "updated" links from message of @flash2b?
Yes, I thought that too.
Offline abeyer
« Reply #12 on: October 12, 2025, 07:29:55 pm »
the latest on the site (as of yesterday) is labeled "Third Edition SLYY138 - 12/2024"
Offline tooki
« Reply #14 on: October 12, 2025, 07:43:52 pm »
The PDFs are too big to post here. Can’t you just quickly re-register on the website?
Offline ohmjke
« Reply #15 on: October 13, 2025, 03:28:49 pm »
I've tried to register with a different email - no success.
Fortunately, found collegue with an active account and was able to download both files.
If anyone else needs it:
https://www.dropbox.com/scl/fi/6mq5xv0eqmqohm8gopadu/slyy138b-Analog-Engineer-s-Circuit-Cookbook-Data-Converters.pdf?rlkey=9fcn5ata28zts98tlk8oodrxp&st=8j3l8t4a&dl=0
https://www.dropbox.com/scl/fi/93f3zjotst6wzxe3lg32d/slyy137d-Analog-Engineer-s-Circuit-Cookbook-Amplifiers.pdf?rlkey=vm6aa3hc92hvrqye79sd5lrcu&st=kqioshhl&dl=0
The following users thanked this post: ledtester, flash2b, al777, Eraldo, the Chris
Offline ledtester
« Reply #16 on: October 16, 2025, 10:08:13 am »
Probably some overlap but no registration needed - a compilation of 100+ analog designs:
(reported in Hackaday... https://hackaday.com/blog/page/2/)
Offline ohmjke
« Reply #17 on: October 16, 2025, 11:20:15 am »
Well, it's the same page I mentioned earlier:
Offline tggzzz
« Reply #18 on: October 16, 2025, 11:27:22 am »
A classic publication, almost 1500 pages long. https://bitsavers.org/components/national/_dataBooks/2003_National_Linear_Applications_Handbook.pdf
The subject index is on (PDF) page 31
Online Gyro
« Reply #19 on: October 16, 2025, 12:10:38 pm »
Yes, the old NS ones were a much more interesting read.
Best Regards, Chris
Offline RoGeorge
« Reply #20 on: October 16, 2025, 12:47:13 pm »
