Sure, running the simulation at different DC
operating points is needed for complete analysis, however, each DC operating point will produce a different load line. For the case of a PA, the device will be "taken" at any given point along the load line (red or blue curve below). Therefore, to ensure complete stability, one must cover all load line states.
The non-linear stability analysis methods state that the response is linearised about the large-signal (HB) periodic steady state (PSS) response. The literature states that the HB simulation takes into account all the various states along the load line (see below). How it does this is one of my questions. The follow figure illustrates all possible load line states used in the PSS analysis.
This is all fine, though the pole-zero identification method used in non-linear stability analysis determines the closed-loop transfer function of the circuit. How can this be achieved when you have multiple load line states, as shown above. Is there not a separate transfer function for each state along the load line?
