Author Topic: Help choosing a capacitory for 3.3v circuite  (Read 3076 times)
Offline sairfan1Topic starter
« on: October 18, 2023, 04:21:39 pm »
I was looking for SMD 0805 10uF capacitor for my 3.3v circuite, when I searched mostly capacitors I found were 10uF 50v I want to know does it still work or its big difference I believe closest I can found could be 6.3v. I wanted to learn how capacitor voltage can impect when supply voltage is way below.
I will be using those capacitors close to VDD/VCC line of different ICs.
Offline Kleinstein
Re: Help choosing a capacitory for 3.3v circuite
« Reply #1 on: October 18, 2023, 04:45:37 pm »
The voltage rating for capacitors is the maximum allowed voltage. Using a capacitor with a higher voltage rating is no electrical problem. The higher voltage ones tend to be more expensive and mechnical larger though, but there is also a question what is available and used in numbers.
10 µF is already quite a large capacitor for decoupling, depending on the chip (especially logic, OPs, low power µCs) less capacitance may be enough.
The following users thanked this post: sairfan1
Offline Zero999
  • 0999
« Reply #2 on: October 18, 2023, 07:01:12 pm »
What sort of capacitor is it: ceramic, tantalum, aluminium?
Most large value ceramic capacitors, in a small package, saturate at a relatively low voltage, compared to their ratings. This means that the capacitance drops, as the voltage increases. A 50V 10µF ceramic capacitor will not have a capacitance anywhere near 10µF at 50V, or even 30V, but at 3.3V, it'll definitely be 10µF. In other words, if it's ceramic, then I would definitely recommend using a 50V ceramic capacitor on a 3.3V rail.
If it's an aluminium electrolytic capacitor, then this isn't an issue, but a 50V part on a 3.3V rail wouldn't be a problem.
Tantalum capacitors have a tendency to smoke when used close to their voltage ratings, especially when subject to high current surges/ripple. Going for 50V is still overkill, but won't do any harm.
Offline alligatorblues
« Reply #3 on: October 19, 2023, 01:35:20 am »
My rule for tqntalum is double the voltage you need.
Offline Vovk_Z
  • Country: ua
« Reply #4 on: October 19, 2023, 02:22:11 pm »
There are several topics about it here.
« Reply #5 on: October 19, 2023, 04:20:16 pm »
its ceramic capacitor, thanks for the explaination.
