Author Topic: Help with choosing resistors  (Read 1022 times)
Offline JohadartTopic starter
« on: November 27, 2022, 07:27:45 am »
Hi, I don’t have a 240 ohm resistor, I’m building a power supply, didn’t come with the kit, any suggestions on what to use in place please?
Offline connectTek
Re: Help with choosing resistors
« Reply #1 on: November 27, 2022, 09:48:37 am »
A 240 ohm resistor of course, a couple of cents.
Online magic
« Reply #2 on: November 27, 2022, 10:23:25 am »
Either that or a different resistor or a pair of resistors ;)
What are the tolerance and power rating specs of the part you want to replace?
For example, 220+22 is 242, which is less than 1% off. 220 alone is 10% off.
In a pair, the 220 will carry most of the load, so its power spec should match the original part.
Offline JohanH
« Reply #3 on: November 27, 2022, 11:26:55 am »
The easiest is soldering two resistors in parallel. Use this calculator to calculate parallel and series resistances. You can set it to output values based on resistor series you have.
https://www.qsl.net/in3otd/parallr.html
For 240 ohm in total, select for instance (based on which resistors you have) 270 in parallel with 2200, which makes it more or less exactly 240 ohm.
« Reply #4 on: November 28, 2022, 12:44:41 am »
Thanks everyone for your answers 🤙🏼
Offline gbaddeley
« Reply #5 on: November 28, 2022, 01:57:47 am »
Or two 120 ohms in series. Perfect power sharing.
Glenn
Online themadhippy
« Reply #6 on: November 28, 2022, 02:11:07 am »
sounds suspiciously like it could be based around something like a lm317? is so  you can change the 240 ohm to something else and recalculate the other resistor
Offline JohanH
« Reply #7 on: November 28, 2022, 08:35:00 am »
There are online calculators for that, too! https://circuitdigest.com/calculators/lm317-resistor-voltage-calculator
« Reply #8 on: December 16, 2022, 02:07:54 am »
Thanks for all your help, got it done. Cheers 🤙🏼🇦🇺
Offline Terry Bites
« Reply #9 on: December 16, 2022, 08:11:11 pm »
I think themadhippy is right on the money here. If its for a regulator feedback divider just use 180 to 330 and recalculate. www.omnicalculator.com/other/lm317
If it doesn't carry more than few mA any series or parallel combo will do. 2 470s in II will give you 235. Good enough?
