That's interesting. I have a PC board power supply also that needs an input from another power supply.
The reason I got that one was so I can get more than one voltage from the main power supply. So, I can vary both now to get voltages from 0v to about 30v DC. Without that second power supply regulator board I would only have one voltage 0v to 30vdc.
If I get a third PS controller board, I can have three outputs all independently adjustable from 0 to 30vdc. I use mostly light current levels, but they will go up to around 5 amps which is more than I usually need.
