Author Topic: Help with DC adapter  (Read 3013 times)
Offline jj5Topic starter
  • Still learning about electronics...
    • In The Lab With Jay Jay
Re: Help with DC adapter
« Reply #25 on: July 21, 2023, 08:00:58 am »
Why don't you just buy a power supply that works from the mains power, instead of needing yet another supply to power the other supply???
My other bench supply is a TENMA 72-10505, but I also have two of these Riden RD6006, and I've got them now, so might as well use them than replace them!
« Reply #26 on: July 21, 2023, 08:03:27 am »
The RD6006 is a buck converter that has a configurable CC mode which is what I bet the OP is relying on to charge the li-ion batteries.
To be clear: I am not charging li-ion batteries. I'm just powering the Riden RD6006 so I can use it for a bench supply.
Another forum member has developed an alternative firmware which improves the UI and adds more features. More info is available at:
https://www.eevblog.com/forum/testgear/ruideng-riden-rd6006-dc-power-supply/msg4971583/#msg4971583
Cool! I will check that out, thanks very much.
« Reply #27 on: July 21, 2023, 08:05:14 am »
Ok, are you good to go?
I am indeed. Thank you again for your help! I have rewired the HP AC adapter and it is now powering my Riden RD6006 providing 19.94V:
So I'm not sure what problem I had in the first place when I made the initial post on this topic. I didn't read any voltage, but there is voltage. Probably operator error!
« Last Edit: July 21, 2023, 08:08:03 am by jj5 »
Offline MrAl
« Reply #28 on: July 21, 2023, 02:21:18 pm »
That's interesting.  I have a PC board power supply also that needs an input from another power supply.
The reason I got that one was so I can get more than one voltage from the main power supply.  So, I can vary both now to get voltages from 0v to about 30v DC.  Without that second power supply regulator board I would only have one voltage 0v to 30vdc.
If I get a third PS controller board, I can have three outputs all independently adjustable from 0 to 30vdc.  I use mostly light current levels, but they will go up to around 5 amps which is more than I usually need.
Offline gnuarm
  • Country: pr
« Reply #29 on: July 21, 2023, 05:10:29 pm »
You aren't done until you've drawn some significant power from the unit.  It might be that the brick puts out a minimal amount of power until the protocol verifies the compatibility of the brick with the laptop.  Let us know when you've drawn an amp or two.
Rick C.  --  Puerto Rico is not a country... It's part of the USA
  - Get 1,000 miles of free Supercharging
  - Tesla referral code - https://ts.la/richard11209
« Reply #30 on: July 22, 2023, 12:15:32 am »
Okay, will do. But what is the best way to do that? I don't yet own a programmable load. Can you recommend a programmable load which is cheap and would be good for this job? I would like to own a programmable load and maybe I could use this as an excuse to buy one... or otherwise how do I introduce a load for testing?
Offline gnuarm
  • Country: pr
« Reply #31 on: July 22, 2023, 12:25:54 am »
https://www.ebay.com/itm/275384331361?hash=item401e2f6c61:g:GUsAAOSwxOFizUaY&var=575829112157
The following users thanked this post: jj5
« Reply #32 on: July 22, 2023, 01:07:17 am »
I was thinking I might get one of these EBD-A20H Battery Testers, what do you think?
« Reply #33 on: July 22, 2023, 01:11:23 am »
Thanks! I will get 12Ω 25W for testing 12V at 1A and 6Ω 25W for testing 12V at 2A. Will that be good enough do you think?
Offline gnuarm
  • Country: pr
« Reply #34 on: July 22, 2023, 01:27:38 am »
How high will your output voltage go?  Why can't you test 2A with one resistor?   I would get the higher wattage resistors.  The rating is just a number.   24W into a 25W resistor will get really hot.  I had some 1 ohm resistors in series running around 5 amps, so 25W each, and 50W parts got hot enough to char wood if left running overnight.  That's hot!  Now, I bolt them to an aluminum plate to act as a heatsink.
« Reply #35 on: July 22, 2023, 01:40:37 am »
Probably not more than 12V. This is just a bench supply for playing with digital electronics. I'm expecting to use 5V, 9V, and 12V. Also the occasional small voltage for testing LEDs.
Well I can. I just figured I would test in stages... not necessary you reckon? Just go straight for the maximum?
Thanks! I will get 6Ω 100W for testing. Will that do?
Offline gnuarm
  • Country: pr
« Reply #36 on: July 22, 2023, 02:39:15 am »
You can change the power level by adjusting the voltage.  If you want to test multiple power levels at the same voltage, then use different resistors.
If it works for you, it works for me.
Offline MrAl
« Reply #37 on: July 22, 2023, 02:48:21 am »
A 100 watt incandescent light bulb will give you low Ohms like around 8 or 10 Ohms at 12v.
Offline gnuarm
  • Country: pr
« Reply #38 on: July 22, 2023, 03:09:33 am »
You can't buy them in the US any more.  At least, they are hard to find.  A 75 W incandescent bulb should work though.
Offline BILLPOD
« Reply #39 on: July 22, 2023, 01:31:44 pm »
Automotive bulbs work fine for low voltage loads.   My headlight bulbs draw approx. 5 Amps on low beam, and 7.5 A on high beam, at 12 VDC.
Offline MrAl
« Reply #40 on: July 22, 2023, 04:10:21 pm »
Yes you really have to have one already.  Some of us do.
Offline gnuarm
  • Country: pr
« Reply #41 on: July 22, 2023, 07:43:56 pm »
You need to be careful with light bulbs.  They have very low resistance when cold, which rises when they start to heat up.  Do not count on them having the resistance you need.  If you manually adjust the controls, they should be fine.
« Reply #42 on: July 28, 2023, 11:29:38 am »
Hey Rick. My 100W 6Ω resistor arrived today and I finished the testing. Turns out the AC adapter in question could deliver more than its 45W maximum rating. The write-up for my testing is here. Thanks very much for your help with this one!
Offline gnuarm
  • Country: pr
« Reply #43 on: July 28, 2023, 11:42:32 am »
I found I was able to read your web page in Reader View in Firefox.  Otherwise, the color scheme would have made it very difficult for me.
« Reply #44 on: July 28, 2023, 11:45:13 am »
Yes, I'm sorry about that. It was designed as a bit of a joke, but it's not very practical. I should probably change it. In the mean time thank goodness for Firefox Reader View. :)
« Reply #45 on: July 28, 2023, 11:55:16 am »
I fixed this now. Thanks for your feedback!
