Guys, I desperately need some advice in my design.
I'm trying to build a 24V input to +12V output power supply with MC34063 that should be able to give me 1.5A.
This current requires an external transistor as the peak current goes to 3A. First I decided to use a NPN like in the schematic:
With this schematic the transistor overheats very quickly even at 0.4A. Obviously I have not selected the right power for it - it was a ZTX857.
Then I decided to try with a MOSFET IRF540 like this:
It turns out that this time I have made another error. The MOSFET gets very hot at 0.4A too.
What to do now? Can you help me to build it?
I have read the datasheet, used the online calculators and tried to calculate with the formulas, but obviously newbies always make mistakes.
Oh, and one last question - what should be the power of the shunt resistor - is 0.5W enough?
Thank you
