Wow, that's a lot to digest. That's quite educational, but regardless, I think I'll get clamp amp meter
1. I butchered the strip and those SMD things are indeed 27ohm resistors soldered in before data lines (not sure why the writing on them says 27
0)
2. For power I'm using USB power supply that says it's capable to provide 2A (tested again two different models just to be sure).
In the original test it passed through breadboard powerboard:
https://photos.app.goo.gl/R2zEqWCp6rBhZ4SHAReading the replies again, I tried to replicate the setup, with different strip though, since I already used that one. This time I powered the strip directly from the USB charger. Then tried to hook it through breadboard to clamp in the DMM, and even before hooking DMM there was noticeable drop in brightness. I guess Kasper is right and jumper wires / breadboards are not good for passing current.
Direct:
https://photos.app.goo.gl/C1TZu2VyqMpcDWKP6Through breadboard:
https://photos.app.goo.gl/xyLTHYgBfuXZmcvC6(It's less evident on pictures, but for human eyes different was rather visible)
Since breadboard/wires produce so much variance/noise, it does not seem rational to continue experiments about measuring current.
When powering directly through usb-pcb the voltage readings on the latter were as follows:
No-load: 4.98v
10 leds: 4.95v
20 leds: 4.75v
30 leds: 4.60v
40 leds: 4.43v
45 leds: 4.31v
50 leds: 3.54v
Each lead can consume up to 60mA on full brightness, so with 2A power supply it should be able to power 30 leds easily.
What's interesting is that even with 50 leds and there was no noticeable drop in brightness. Hence, if every led consumes 60mA max, 50leds * 0.06A * 3.54v = 10.6W, which equals to 2A * 5V as stated on USB charger. Meaning the charger does what's written on it. It least some useful outcome
Thanks again everyone for your replies!
