With a 1.4khz cal output, you are going to have something like a period of 714 microseconds. To fit a whole period on the screen your horizontal timebase will be something like 100 microseconds per division.
With a time constant of 22 nanoseconds, you will not be able to see the difference.
A higher frequency square wave would be better.
You could raise the resistor to 1 meg, but then your probe will start loading it down.
