Author Topic: Newbie Scope: Things that aren't square...  (Read 21984 times)
Offline tooki
Re: Newbie Scope: Things that aren't square...
« Reply #25 on: January 13, 2024, 11:50:40 am »
Someone in a related topic gave an advice of switching your probes to x10 and wrapping the switches over with insulation tape to make them stay in that position, and that's a good advice.
I would only add that it's better to use a heat shrink tube for this: it looks better and does not leave a sticky residue.
Yep. Or just replace them with fixed x10 probes! (For example, the basic x10 probes from Testec only cost about €15 and are way nicer than Rigol’s probes.)
Offline PA0PBZ
« Reply #26 on: January 13, 2024, 02:09:54 pm »
It's a rainy Saturday here so I created your circuit and measured twice: 500MHz bandwidth and 20MHz bandwidth, see pictures and note the difference.
I didn't have (didn't want to search too long) a 18MHz crystal so I used a 16MHz one, shouldn't matter.
500MHz:
20MHz:
The following users thanked this post: tooki, NivagSwerdna, pdenisowski
Offline NivagSwerdnaTopic starter
« Reply #27 on: January 14, 2024, 09:12:21 pm »
Very nice.
Comparing those with my pictures from post#17...
https://www.rigol-uk.co.uk/product/rigol-ds1052e-50mhz-digital-oscilloscope/
So my scope is allegedly
50MHz
and it was 'tweaked' with some firmware hack to be '100MHz'...
I would have thought my pictures would look better?
Offline tggzzz
« Reply #28 on: January 14, 2024, 09:18:19 pm »
If you can see  a 3.5ns risetime, then it is 100MHz.
If you can see a 7ns risetime, then either it is 50MHz or you are seeing the signal's risetime.
Offline ebastler
« Reply #29 on: January 14, 2024, 10:05:05 pm »
Yet another way to implement this: On many low-cost probes (including the ones from Rigol which I have), you can simply pop out the little "grip" piece of the slide switch. That leaves you with a nicely recessed switch which can still be moved to 1x with a small screwdriver in the rare situations where you need that -- but otherwise can't be moved inadvertently.
The following users thanked this post: shapirus
Offline IDEngineer
« Reply #30 on: January 15, 2024, 04:08:52 pm »
I suspect you have a (probe) connection issue at work too. I believe I can see your top, yellow trace riding on what looks to be a sine-ish lower frequency. I'd double check your physical connections. Can't accurately diagnose a signal until you're sure it's ONLY that signal you're looking at!
