In your opamp_JDB_bode_plt.asc , why DC 0.6V input stimulus for Vin+ ?
And why are you not using large LC for DC feedback ?
The op-amp will only work properly if both inputs are within the common mode range and the output is between the supply rails.
If I step the input voltage and measure the Bode plot:
I have changed the feedback to be a voltage follower, that is a gain of +1. A negative input would require the output to be negative. It can't go negative because we only have a positive supply. So the output would be near zero and there would be no gain.
If the input is 0V, the circuit will work for positive half-cycles, but not negative half-cycles. If the input is positive, the circuit works properly.
I get these results:
If I look in the time domain, transient analysis, and I step the voltage and apply a 100mV peak 1kHz sinewave, is see this. You can see that this op-amp doesn't work if the output is required to go negative.
You can also see that this op-amp has a 'defect' called phase reversal when the inputs are near or just below zero.
The choice of using an LC or positioning the voltage source like I did is preference.
Jay_Diddy_B
