.meas TRAN TIME_1 TRIG V(Vin)=0 RISE=2 TARG V(Vin)=0 RISE=3.meas TRAN TIME_2 TRIG V(Vin)=0 RISE=2 TARG V(Vout)=0 RISE=2.meas phase param 360*(TIME_2/TIME_1)
With the .tran 0 1m .5m command from the sim you attached, I am also getting about 80 deg, confirmed by cursor measurements. With your original .tran 50m I'm getting the same bogus 63 deg you got.I suspect the cause is too many cycles and not enough data points due to your initially ill-chosen simulation duration.
