Author Topic: Precision, low DA and low value capacitor (1-10pF)?  (Read 3726 times)
Offline AtomilloTopic starter
« on: February 07, 2022, 05:26:35 pm »
Hi:
I'm trying to design a current integrator in order to measure accurately really small currents (pA-fA). I'm choosing an integrator in order to avoid the high TC, uncertainties and other unpleasant side effects of using a Gohm order feedback resistor in a TIA.
Unfortunately it seems that 1/10pF capacitor with low DA and tolerances of around 1% are not readily available. Does anyone know of any source?
Many thanks!
Offline bob91343
Re: Precision, low DA and low value capacitor (1-10pF)?
« Reply #1 on: February 07, 2022, 06:24:06 pm »
Make one yourself.
Online Kleinstein
« Reply #2 on: February 07, 2022, 06:25:18 pm »
For the low values one could build an air capacitor. When you carefully measure the dimensions one may even calculate the capacitance from first principles. This especially works as a 3 wire capacitor with a separate shield / ground. So one has a shield plane with a hole and an isolated plate to both sides that covers the whole hole.
Normal SMD parts would not help, as the is usually parasitic capacitance of a few 100 fF around a 0805 size part.
Alternatively one would build the measurement tool from more normal parts and than use a known current in the calibration. So like with many other meters: no accurate scale factor from the part tolerances but a measured scale factor to include the individual part variations. So one may need the accurate capacitor only for the calibration, and this may use a slightly larger one.
The following users thanked this post: MK14
« Reply #3 on: February 07, 2022, 06:45:05 pm »
Yes, making seems like the easiest most accesible way. In "Whats this Teflon stuff anyhow" just twisting a wire with a teflon isolated wire works. Pease also builds capacitor in just the way Kleinsteins describes.
But then that means either buying a pico ampere current source (which seems quite expensive in eBay) or an LCR meter capable of measuring such low capacitances accurately (also not cheap). So it would mean going ever deeper in this rabbit hole (not that I would complain too loudly)
EDIT: suppose I should have said "commercial" Precision, low DA and low value capacitor in the title
Offline mawyatt
« Reply #4 on: February 07, 2022, 07:06:02 pm »
Some of the various nanoVNAs flavors might prove useful for measurements, and they are not expensive!!
Best,
~Wyatt Labs by Mike~
« Reply #5 on: February 07, 2022, 07:07:49 pm »
Some of the various nanoVNAs flavors might prove useful, and they are not expensive!!
Best,
Using a NanoVNA to measure this would be great because then I would also have a general purpose instrument useful for other things too!
I have to research the accuracy of this method but thanks for suggesting it I had not even thought about it
Offline bob91343
« Reply #6 on: February 07, 2022, 08:33:02 pm »
The nanoVNA has got to be the most versatile piece of test gear, and an incredible bargain as well.  Every electronics experimenter should have one.  I can't say enough good about this little wonder.
Offline David Hess
  • DavidH
« Reply #7 on: February 08, 2022, 02:18:13 am »
Make one with a length of RG-336 or RG-178 or similar Teflon coaxial cable, or use a twisted pair.
The following users thanked this post: Atomillo
« Reply #8 on: February 08, 2022, 12:07:15 pm »
In the case of coax, to which terminal should I connect the shield?
I would say to the input of the op amp so that it stays at ground and thus also acts as a shield but I'm unsure
Online Kleinstein
« Reply #9 on: February 08, 2022, 12:43:55 pm »
If one would use the coax capacitance as the capacitor for a low current integrator, the input node should be the inner conductor, so that there is not extra noise pick-up. The outer conductor would be the OPs output - there a little hum current would not do much harm.
I would still prefer a mechanically defined capacitance. Teflon is relatively low DA, but still not as good as air.
« Reply #10 on: February 08, 2022, 12:59:45 pm »
The problem with a mechanical defined capacitor is actually making one  |O
I doubt I have neither the skills nor the materials to make a stable, low leakage air capacitor. And going with air one of course also has to worry about humidity degrading leakage which is not fun.
I've found an exaple of a Teflon wire being used as a low DA low leakage capacitor: in the AC board of the HP3458A, as the holding capacitor used in the synchronous sampling method. Of course they didn't need a stable and accurate value of capacitance, but the fact that it was good enough in terms of DA and leakage is encouraging.
Offline David Hess
  • DavidH
« Reply #11 on: February 08, 2022, 04:43:18 pm »
The large volume of an air capacitor means that they suffer from cosmic ray strikes so a Teflon capacitor may be preferred.
Offline magic
« Reply #12 on: February 13, 2022, 10:14:33 am »
I built a parallel palate capacitor to check my LC100-A meter and it turned out a spectacular fail.
The capacitor was made of 22×67mm copper clad plates (copper side inside, no worries) separated with thin 13.1mm plastic spacers. It was supposed to be 1pF, but it measures 2.5pF :scared:
This reminded me that the simple formula we learned in kindergarten is only supposed to work for plates that are large with respect to their spacing. I'm nevertheless surprised that the error can be so bad. And of course it's a big problem, because constructing or measuring a closer spacing with accuracy will be a little more difficult.
As a fallback, I stuck two parallel wires into the meter and used the balanced transmission line capacitance formula to estimate their capacitance:
C=l·π·ε/acosh(s/d)
where l is the length, ε is permittivity of the medium (air), s is the spacing between centers and d is the diameter.
This came out at 180fF vs measured 220fF. I guess there may still be some effect at the end of the line, and of course there is another problem with measuring such low capacitance: even a single conductor connected to the meter has nonzero capacitance to the meter's ground itself. Well ::)
Offline magic
« Reply #13 on: February 13, 2022, 12:15:17 pm »
Could this be made to work in practice?
If true, you could measure your pF capacitors with a single good 100nF, a few resistors and TL072.
Offline Terry Bites
« Last Edit: February 14, 2022, 10:23:43 am by Terry Bites »
« Reply #15 on: February 15, 2022, 06:20:58 am »
https://datasheets.kyocera-avx.com/ML03.pdf
Interesting read: https://www.kyocera-avx.com/docs/techinfo/RFMicrowaveThinFilm/MLO_Dielectric_Absorption.pdf
Full LT spice simand practial example from AD https://munin.uit.no/bitstream/handle/10037/6783/thesis.pdf?sequence=2
Many thanks for your help. Unfortunately as Kleinlein stated, with SMDs capacitors it seems difficult to eliminate all parasitic capacitances. Even more so when we consider that it will be air mounted to prevent leakage.
In the same line, it is interesting that nowhere in the datasheet do they mention leakage current.
I'm just starting to conclude that the only capacitors approaching the necessary specs are those used as low capacitance standards. Which of course are way out budget wise.
Offline magic
« Reply #16 on: February 15, 2022, 07:56:49 am »
I suspect you may encounter other problems too, like additional capacitance in wiring (THT is not entirely immune) and even between pins of the opamp (particularly in a dual).
OTOH, how hard would it be to calibrate the complete ammeter with a current source way above pA? I mean, 1pA going into 1pF is 1V/s slew rate. Clearly, you should be able to shove 1nA or maybe even 1µA into it and still be able to measure the resulting slew rate? Such currents should be much easier to generate - some voltage source, resistors, bingo.
« Last Edit: February 15, 2022, 07:59:01 am by magic »
Online Kleinstein
« Reply #17 on: February 15, 2022, 08:21:52 am »
The problem with the parasitic capacitance does not only apply to SMD parts. THT parts are not better in this respect. For high curruracy at those small values one needs a shielded capacitor, so not just a 2 pin device, but at least a 3 contact construction with an extra shield, so that the parasitic capacitance is towards the shield and not between the 2 contacts for the measurement. The accurate capacitance is only the coupling between the 2 hot terminals, not the overall capacitance.
The integrator itself works better with a physical small part like a SMD C0G cap to reduce the effect of radiation spikes in air and keep the capacitance to ground low, as it can effect stability and noise.
Instead of using a low tolerance capacitor it may be much more practical to measure the sensitivity of the integrator afterwards to include all the parasitics. This may be relative to a larger capacitor, that is easier to get with reasonable good accuracy. Also calibration relative to an accurate high ohms resistor may be possible, though also not easy to get.
With small C0G capacitors the leakage across the cap is often less than the parasitic one via the board. It also depends a lot on cleaning. So there is little value if they would give leakage specs as in the normal use other leakage paths are more relevant and a measurement is difficult.
Offline Terry Bites
« Reply #18 on: February 18, 2022, 02:11:56 am »
You can alway phone their engineers- try that human touch.
Offline magic
« Reply #19 on: February 18, 2022, 08:12:55 am »
Humans also have parasitic capacitance to ground, they can't help you with that aspect of the circuit :P
Offline Berni
  • Country: si
« Reply #20 on: February 18, 2022, 08:22:36 am »
You should NOT trust the capacitor to have the exact capacitance you want in the first place.
Even if you could buy a 0.1% tolerance capacitor for the exact thing you want, this capacitor still has to be wired into the rest of the circuit and this introduces extra parasitics, easily throwing off the original value by quite a few %.
When going for high levels of precision it tends to be best to just focus on the value being stable over time/temperature. So just get a capacitor you think will be most stable, then calibrate your DIY instrument with a known current.
Unfortunately working with picoamp things indeed get more difficult and expensive. You will need some sort of calibrated current source or an instrument capable of measuring such low currents to construct your own current source. I would recommend getting an old Keithley electometer (those in the ugly brown cases) as they can sometimes be had for a good deal and can measure bellow 1pA
Offline jonpaul
« Reply #21 on: February 18, 2022, 09:29:59 am »
Bonjour Atomillo:
Just reading  this long thread now, we have used since 1980s  high gig R and small C.
But You did not mention the source of the current or system setup. Still we can comment:
 1/ Your root goal, measurement of small currents (pA-fA) is  best handled by an electrometer, the old Kiethley 610C are designed for such use and have the appropriate gigohm R and very low leakage input connectors and amp JFET.
https://122.physics.ucdavis.edu/course/cosmology/sites/default/files/files/Ferro%20Electricity/Keithley610manual.pdf
2/ A DIY electrometer needs a special input amp or opamp, and teflon connectors. The feedback element can be a metal oxide R available from Victoreen, Caddoc, and other high R vendors. Expect 1 % accuracy at best.
3/ pF capacitors are not made in SMD nor at high precision. GenRad made some large and costly precision air cap standards, available on Ebay, ~$100...500
4/ Any pF measurement must be a 3 terminal guarded bridge or RLC meter, with no guard the measurement is very inaccurate.
5/ Slight lead position changes will dominate the test of pF C, you need a ridgid  test fixture, with guard, and you must first zero out the test setup stray capacity.
6/ We measure with vintage Tektronix 130 valve LC meter, 3 pF lower range up to 75 pF zero capability.
Another good meter is the HP 4332A. They have  the required  guard voltage capability.
7/ The capacitor is fabricated  with metal spheres (NOT PCB!) and teflon or delrin, nylon insulators as per good high voltage  technique.   One simple low capacity topology is two equal diameters spheres, like  a spark gap.
8/ The formulas for capacitance are well known, and calculators available online for parallel plates, spheres, single sphere above ground plane, etc.
9/Our calibrated HV sparkgap is a  pair of 50 mm metal sphere son  5 mm rod supports , 30 mm dia   Lucite columns supports 200 mm spacing. We read ~ 2pF guarded C between spheres with  gap is 15 mm
10/ A parallel plate capacacitor of PCB matériel  will have higher C than calculated for a metal plate due to the PCB insulation layer diélectrique, eg FR10 fiberglass.  You must account for the electric field on the back of the plates.
Hope this note is interesting,
Bon chance,
Jon
« Last Edit: February 18, 2022, 10:12:25 am by jonpaul »
Jean-Paul  the Internet Dinosaur
« Reply #22 on: February 19, 2022, 08:34:02 pm »
Hello:
Sorry for being slow to respond. I've just started a new semester this week and things have been a bit heptic.
There is not a specified system as such. My main target was to reliably and accurately measure down to the 10s of fAs. No need really, just a fun task :) I was aware this would be a challenge as I had some experience with measuring pAs.
My problem with the main idea suggested in this thread (i.e to focus on stability and calibrate the meter using a known low current) is actually generating such currents. Used, unknown state, Keithely 261 shipped to Spain are around 350 euros in eBay. That's way beyond my budget and my appetite for risk. And of course then I had to spend more money to calibrate it in order to perform meaningful measurents. With that in mind, the only option seemed to be to find an accurate method right out the gate.
Of course, high value resistors have huge TCs and high tolerances so they were out of the question. The idea I came up with is the simple circuit attached.
The reset switch is placed across the output of the op amp, along with a resistor used to avoid damage to the op amp without effect in normal operation. Normally, in the most common topology that uses this circuit (I->F converter) this is bad, because when the switch closes the op amp saturates, and then has to spend time out of saturation, which greatly damages output frequency linearity. In my case however, I would be measuring only the slope of the output signal, and doing it this way allowed me to use a common switch without having to worry about leakage or such.
At the time I assumed that capacitors with the necessary characteristics were easier to find thn high value resistors and such. This topic and the great responses by Jon Paul, Berni, Kleinstein, etc... have showed me I was wrong. After reading and following the clues provided, I also reached the conclusion that perfoming pF measurements is an art on it's own, not something to be kludged together in an evening.
After putting some though on this, I came about with an idea about a single slope current meter. And while now the absolute tolerance and TC of the capacitor is unimportant and measuring times in this scale is very easy nowadays, the problem turns into generating precise 1/10uA current pulses with 1/10/100uS widht and very low leakage when turned off. While I have some clues, that is not a matter for this thread, and to be honest, I'm not even sure if it can be accomplished.
Many thanks to all who responded for making me a lot more knowledgeable when it comes to low capacitance measurent and hurdles
Offline magic
« Reply #23 on: February 19, 2022, 08:59:39 pm »
You came late to this party.
Just a few years ago you could buy 1GΩ 0.5% 25ppm/°C resistors at Mouser for ten bucks. But they stopped stocking them at about the time I got mine. Somebody snagged the last 100GΩ right before me. I now looked at the prices and availability today :scared:
« Reply #24 on: February 19, 2022, 09:26:51 pm »
I feel like that's true for a lot of TE things.
I see old threads talking about the price of used HP34401A; and then look at what I paid for mine... I was lucky to find what now is a "good deal".
It seems everything has become more expensive
