I think RoGeorge has made it quite clear that he was discussing real photons as opposed to virtual photons..
Real photons have an indefinite lifetime as a ‘particle’.
I think also we can set aside negligible effects until the basic question is answered.
I don't think "lifetime" is the appropriate concept for a real photon. If you mean the time between its emission and its eventual interaction with matter, that is simply a propagation time determined by the particular setup, not a lifetime of the photon itself.
More importantly, I don't think the photon concept even gives us a meaningful way to identify a particular photon as "the same photon" at emission and detection. We can prepare a one-photon state at the source and later observe a photon detection event at the other end, but this does not mean that we have tracked an identifiable object travelling between the two events. We cannot say that we are dealing with the same photon.
Consider pouring one litre of water into one end of a pipe and collecting one litre at the other end. The water coming out could simply be water that was already inside the pipe, rather than the particular water that was poured in. Conservation of the amount of water does not establish the identity of the material that came out.
With photons the situation is even more fundamental: identifying "the same object" presupposes an object with an individual identity that persists through spacetime, i.e. essentially a classical corpuscular picture. That is not how a photon is represented in quantum field theory.
And if a photon never interacts with matter, there is no particular event at which its "lifetime" starts or ends. In fact, a photon that never interacts with matter cannot be detected in the first place, so claims about the "lifetime" of such a photon are not experimentally testable. At that point we are no longer discussing an experimentally observable property of a photon.
Thank you for your answer, I can’t tell whether you are agreeing or disagreeing so taking your points one at a time:-
Lifetime is one of those terms that actually stands for a whole class of concepts. This is why I simply said indeterminate.
But we have to call it something. Have you alternative suggestion ?
But yes I mean the time between creation and annihilation. This can in fact be determined for the photons from Alpha Centauri in RoGeorge’s camera, but not for the ones that miss Earth completely.
We know when the photon arrives and can calculate when it must have started its journey.
Despite what Showman says, we also know its size limit since it must obey Heisenberg. This is exceedingly small since it must be confined to a volume within the HUP in order for the energy to be transferred, again within the HUP time constraints, to the absorber/detector.
This is basic QM.
This is why your analogy does not ‘hold water’.
I have suggested a better classical one at the end.
Basically agreed.
This is more advanced QM than already noted and involves some extra postulates.
These involve the “Indistinguishability of identical particles” postulate and new state vectors for systems.
This subject does not usually appear in elementary treatments.
A really good mathematical treatment is given in Merzbacher “Quantum Mechanics”, Wiley, Chapter 20 page 508.
His book is good because it goes into the supporting background as well as, rather than concentrating on, the mathematics (Bra /Ket or whatever)
Basically correct for a virtual photon, but we are dealing with real photons, remember.
And as I have already mentioned, the time between their appearance and disappearance is governed by the HUP and exceedingly short.
Real photons are always the result of a material event so must have a definite start time but I agree there is no defined end time.
Again returning to the OP.
Pressure provides a good analogy for what is happening.
Consider a litre of gas at some reasonable pressure P1.
We see this as a force smoothly spread over the entire surface of the container.
This corresponds to the smooth description of the radio wavefront.
Yet we know from the kinetic theory that this smooth pressure is actually made up of a very large number of momentum transfers form moving molecules.
In the same way the photon model suggests that the wavefront is actually made up of and even larger number of smaller particles called photons, capable of transferring specific amounts of energy in a macroscopically smooth manner.
Now let the gas expand or exhaust some from the container.
Eventually we will reach the situation of loosing that smoothness and being able to detect individual strikes.
This is the same situation with RoGeorge and his Alpha Centauri camera observations.
Note I am not claiming the gas model is identical to the photon model. There are differences.
But I do suggest it is useful in this case.
