A family member brought me a Yamaha CMVP-207 piano that was not working to try and repair. It would play sound from the audio in port but nothing from the piano keys. The full schematic can be found in the service manual but I've attached the relevant part below.
I traced the issue down to the two PCM1702U DAC's which are no longer made. I looked on ebay and found some... but I think they are fake because while it actually played sound from the keys (unlike before), the audio quality was horrible. When debugging I noticed the -5V regulator was overloaded (the -5V net would only reach -0.72V) making the pcb hot. I couldn't find any shorts so I removed the two ebay chips and all the digital signals and +5V and -5V are present.
After some l searching for alternatives, I found
https://www.ti.com/product/PCM1794A which I think maybe could be used with a small converter pcb that adds a 3.3v regulator, configures the PCM1794A via hardware pins, and re-routes the traces as needed. Would this work?
If the PCM1794A is put in MONO mode with Standard 24-bit format (shown in section 8.1.3 in the PCM1784 datasheet) will it work with the same digital signals the PCM1702 used?
I'm also confused how the different analog outputs would be converted. The PCM1702 takes +5 and -5 inputs with one L output, while the PCM1794A has a L+ and L- output but only takes a 5+ supply. Could I just cut the AGND connection on the "+" of the output Op amp (UPC4570G2) then run the L+ and L- of the PCM1794A and to the "-" and "+" of the op amp?
Is there another part (or approach) that would work better or can the PCM1794A be used? Any help would be appreciated!
