My 2 cents.
*IF* you are using solderless breadboards, some of those resistor kits have parts with really thin leads which don't make good contact in the sockets. For solderless breadboards, I want to use the older style 5% 1/4 watt with thicker leads.
Secondly, the 1% color ring coding is not easy to read. Again, I like the older 5% style. I can have the resistors in a pile on my bench and easily spot the 1k, 10k, 3.3k, 22k etc. With the 1% type, I have no idea and have to measure them.
For most stuff, 1% isn't needed. I do have 1% and 5% kits, but for the reasons I mentioned, I only use the 1% when there is a need (which isn't often). For SMT resistors, neither of my complaints with the 1% leaded kits apply, and I get 1% kits.
For the common 10x values: 10, 100, 1k, 10k (and similarly capacitors 10uF, 1uF, 0.1uf, 0.01uF, 0.001uF) I just buy 100 of each from Digikey or Mouser. (for SMT I might buy 250 of each)
