Author Topic: Reverse polarity proptection with P MOSFET  (Read 574 times)
Offline anso-engineerTopic starter
  • Country: ua
« on: June 03, 2026, 09:39:15 am »
Hello, I checked some reverse polarity protection and looks like it isn't totally protect.
Current still goes (probably through the body diode)
Is this schematic can be reliable at all?
Offline madires
  • A qualified hobbyist ;)
Re: Reverse polarity proptection with P MOSFET
« Reply #1 on: June 03, 2026, 10:29:54 am »
Please try again with drain and source swapped. ;)
Offline golden_labels
« Reply #2 on: June 03, 2026, 10:50:08 am »
Madires gave the solution. Supplementing that with some explanation: you used MOSFET as a switch. While in this circuit it acts as an approximation of an ideal one-way valve.
Why 📎 | We live in times when half of people have IQ below 100.
  • Country: ua
« Reply #3 on: June 03, 2026, 03:05:45 pm »
It works  :)
Could you explain, how Q1(S) point got 11.94V?
Offline ledtester
« Reply #4 on: June 03, 2026, 03:32:07 pm »
It works  :)
See this video at 2:09...
How to protect circuits from reversed voltage polarity! -- Afrotechmods
https://youtu.be/IrB-FPcv1Dc?t=2m9s
The following users thanked this post: anso-engineer
Offline madires
« Reply #5 on: June 03, 2026, 03:35:08 pm »
The voltage drop of the MOSFET is R_DS_on * I_load when fully turned on. Your simulation software assumes an R_DS_on of about 90 mOhms (I&R datasheet: 117 mOhms).
« Reply #6 on: June 03, 2026, 04:59:00 pm »
Watch the video linked by ledtester from 00:00, not 02:09. It explains what is the purpose of the MOSFET.
In short: there is still a diode to control direction. But if the polarity is correct, the MOSFET provides an additional path in parallel. That path is still no 0 Ω, though.
  • Country: ua
« Reply #7 on: June 04, 2026, 01:09:20 pm »
Observed the video and extra ressources.
Main my misunderstading was that this body diode acts as regular diode. So diode is foraward biased, and we simly get the voltage on the side with "Source" pin.
I have observed some schematic, and looks like PMOS ususally conneted as high switch, where mosfet diode is reverse biased. This is the reason why I got confused.
