Author Topic: shitty chinese psu kit  (Read 58099 times)
Offline xavier60
Re: shitty chinese psu kit
« Reply #200 on: March 18, 2022, 08:52:10 pm »
D17 could be replaced with an LED but the current might be too high for it. A better way is to put an LED and resistor in series between the 12V control rail and the output of the CV opamp. Start with 10K or a bit lower to see how the LED brightness is.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: m3vuv
Offline m3vuvTopic starter
« Reply #201 on: March 19, 2022, 04:43:36 am »
is that u1a pin1 or 7? and the amp control rail or volts control rail?,thanks.
Offline xavier60
« Reply #202 on: March 19, 2022, 04:48:33 am »
If you want the LED to indicate CV status, it needs to connect to the CV opamp U1B output pin 7.
The power source needs to be 12V from the 7812.
What did the reference voltage measure??
« Last Edit: March 19, 2022, 06:20:18 am by xavier60 »
« Reply #203 on: March 19, 2022, 06:05:58 am »
what ref voltage are you talking about?,i havent checked any,is that not how the led is alread conected?
Offline xavier60
« Reply #204 on: March 19, 2022, 06:09:13 am »
Im still curious about the 2.5V reference I asked you to measure yesterday. In case the TL431 really has been damaged.
The following users thanked this post: m3vuv, kallek
« Reply #205 on: March 19, 2022, 06:31:00 am »
didnt check it as the psu was working ok,well up to 10a anyway,i am more concerned over the cv connections,although thats icing on the cake imho.
Offline xavier60
« Reply #206 on: March 19, 2022, 06:34:45 am »
I'll standby until you get a chance to check it.
« Reply #207 on: March 19, 2022, 07:13:45 am »
whats the point in risking shorting pins probing to check the ref voltage when the psu is working fine,i just want to know where to connect a cv led.
Online ebastler
« Reply #208 on: March 19, 2022, 07:48:39 am »
Wow, five weeks of tinkering and nine pages of forum dialog on a $20 power supply kit. I guess we can't complain about the value for money one gets out of this kit...  ::)
The following users thanked this post: Gyro, MK14
« Reply #209 on: March 19, 2022, 07:55:26 am »
at least it gave you some reading!
Offline MK14
« Reply #210 on: March 19, 2022, 08:24:11 am »
I suppose, it shows that there are many different types of people, in this world.
A reasonably decent kit, with PCB and decent enough supplied components, should be able to be constructed, reasonably quickly and tend to work, first time.
They (presumably) are either buying sub-standard quality kits and/or need to improve their construction techniques, so it doesn't short out and blow components up, every 5 minutes and/or they just can't listen to good advice, and so end up with something so badly bodged together, that it keeps on failing.
« Last Edit: March 19, 2022, 08:26:37 am by MK14 »
Offline MK14
« Reply #211 on: March 19, 2022, 08:36:10 am »
You have got to be joking. The gist of the way it looks to me, is that you keep on saying you swapped this component for another component. This kit for another kit. This component or that component smoked, burnt out, got too hot, etc.
Making it extremely difficult or not possible, to follow/help or get anything sorted out.
It really needs you to supply a schematic, and keep that schematic updated with any changes you make.
« Reply #212 on: March 19, 2022, 08:39:15 am »
well mines been a bit of a battle mostly due to doubling the output,was a good learning curve tho,at the end of the day i have a 0-36v 10amp+psu with cc control for about 30 quid!,whats not to like?.
« Reply #213 on: March 19, 2022, 08:40:51 am »
if you look the schematic + links have been posted.
Offline MK14
« Reply #214 on: March 19, 2022, 08:59:52 am »
But the problem is, I keep on seeing posts, such as this one:
in a nutshell i used four BUW49 transistors as the pass elements,fitted a 50amp bridge offboard,a 22000 uf offboard filter cap and changed r4 too a 1 watt item.the pass transistors are on an old amd pc heatsink with an old ps2 fan.Just need to fit some vents on the case now,its an old pc speaker sub case.
Which keep on changing components, component values and possibly circuit configuration.
Leading to confusion, misunderstandings and difficulty with following what exactly is going on.
« Reply #215 on: March 19, 2022, 02:43:18 pm »
So am i correct in thinking the cv led goes to the lm7812 output via a dropper resistor and u1 pin7?
« Reply #216 on: March 20, 2022, 09:14:19 am »
well i left this running overnight charging a car battery at 14v 1 amp,woke up this morning to find zero output,left it disconnected for an hour and its working againe,could that be the 7812 shutting down thru heat?,if so i plan on building this and fit offboard,is that a good plan?or just fit the existing reg offboard on a bigger heatsink?
« Last Edit: March 20, 2022, 10:57:45 am by m3vuv »
« Reply #217 on: March 20, 2022, 11:59:30 am »
Seems mr wagner made a ballsup with u3 +u7,he has 2xu3 but no u7. on the board layout etc.
« Reply #218 on: March 20, 2022, 12:12:24 pm »
seems we have a u6 on the schematic but not on the pcb!
Offline not1xor1
« Reply #219 on: March 21, 2022, 08:08:41 am »
Unless you attached the wrong schematic or are just trolling that circuit will never work because you will never get 14V and 1A out of 2 78L12 ICs.
Offline xavier60
« Reply #220 on: March 21, 2022, 08:16:16 am »
"m3vuv" is suspecting that the LM7812 supplying the 12V control rail is shutting down.
« Reply #221 on: March 21, 2022, 08:27:11 am »
well i fitted a bigger heatsink to the 12v reg but after steve wagner corrected his pdf docs i realised i had fitted it to the wrong 12v reg,gonna redo it now,may fit a usb charger port hung off of the 5v reg too.
« Reply #222 on: March 21, 2022, 08:31:32 am »
i see the shutdown as a heat issue as the output reterns when its cooled,my board is different to the last as in u3 is hard up against the tl431 voltage ref so dare say heat could cause issues there,going to mount the 12v u3 offboard on a heat sink with caps on the in+ out and try that.
« Last Edit: March 21, 2022, 09:07:35 am by m3vuv »
« Reply #223 on: March 21, 2022, 09:08:35 am »
hope the corrected pdf files help if anyone is planning on building one of these.
Offline Terry Bites
« Reply #224 on: March 21, 2022, 09:51:29 am »
Will this saga ever end?
