Well it is possible that they do some systems like that here too, but apparently not every system because the ones I have seen are as I described exactly. One system was upgraded significantly too and the water mains stayed connected and the plumber left the valve open. I'll try to dig up a picture, but it would just show a mains water line running into the pipes of the hot water heater.
OK, but can you see my problem? If there is a permanent connection between the heating circuit and the mains water, then the water you drink might have been around the radiators a few times, picking up rust and scum. Surely you would agree that such a thing would be disgusting and seems most unlikely. Yes?
Could you address that specific point? I'm just trying to understand how the system you describe works.
Yes I can see your problem, but can you see mine? This whole thing has been questioned as if it could never happen in a million years, yet I have seen two systems firsthand and had direct experience with both systems and described those systems. I explained that, but still there are questions about the validity. The only explanation I can think of is that some people have not had any experience with these systems so they believe it could not be possible, even though someone states that they had direct experience with them.
Well, the other possibility is that we have learned that on the web a lot of information is not reliable at all. I myself also question some things I don't think are possible, but if someone insists then I give them the room they deserve. Still, it's an interesting subject I guess after all so still interesting to talk about.
That said, I am posting a picture of the system. The pipe going straight up is the cold-water mains pipe that comes from the same main pipe as the cold water for sinks. The blue handle valve is the valve that can shut off the mains water feed in case of a bad water leak.
As to the specific point, yes that would be gross ha ha and I'd hate to have that happen, and I actually did address this you may have missed it. I understand though because sometimes these threads get long and involved. We are not alone with our concerns too because apparently one of the plumbing codes is that there has to be a backflow preventer valve, the abbreviation is BBFP and that, from what I understand, stands for "Boiler Back Flow Preventer". Some have TWO check valves inside, not just one. The check valves only allow water flow in one direction ... a "water diode" as it were.
So I think this should set it to rest, but anyone is free to look up that abbreviation as: "BBFP valve" and see that there are several types.
Also, respectfully, is it possible you are confusing the hot water system and the heating system?
In a normal combi boiler installation, the hot water is fed directly from the mains water, through a heat exchanger in the boiler, and out to the hot water taps. So obviously the hot water system has an open connection to the mains water.
But we are talking about the heating circuit, and this is the one I can't understand because a permanently open connection to the cold water mains is guaranteed to mix your drinking water with water that has been around the radiators.
Also respectfully, there is no way I would ever do that because I've worked on these systems myself although not all by myself (someone else with me). I am not a plumber though and do not profess to know everything about plumbing, but I have done some small work on these systems like replacing a hot water tank which is for the hot water feed not for the heater.
As far as being guaranteed to mix drinking water with water that has been in the radiator for 10 years, the BBFP prevents that and that is what those valves are for. Also, I did not install the new updated system a rather large plumbing company did the work. There were three guys working on it ha ha.
So now that we should have this issue cleared up, did I happen to mention yet that the sewer pipe from the toilet connects directly to the cold-water pipe? Just in case the city turns off the mains water we can still get drinking water after the toilet flushes.
Now there is something that is completely unbelievable so I suggest that nobody should actually believe that one
