Author Topic: Surface Mount Component Storage?  (Read 1104 times)
Offline NanoHawkTopic starter
« on: July 21, 2020, 02:40:44 am »
When I searched this topic I came up with one good conversation from 2011.  I'm hoping there might be new ideas out there.
Best option for storing cut-tape SMD/SMT devices?  I'm also curious how you store your reels for things you use often like passives.
I have some Akro-Mils bins for my component parts.  Great bins as long as you don't knock them over.  :)
My first two small SMD break out boards have a small box from Mouser / Tayda / and eBay(China) of components that I brought in for them.  Keeping them in little baggies is going to drive me bananas.
I eventually want to build a lite-placer pick and place machine, but still anticipate working with mostly cut-tape for most parts.
Re: Surface Mount Component Storage?
« Reply #1 on: July 21, 2020, 02:48:50 am »
You can buy empty SMD sample books and fill them with cut tape of your most used values.
Just the one I have has all my 0805 components in one book plus a bunch of LED's, diodes, IC's etc.
Something like this one:
https://www.aliexpress.com/item/32588050685.html?spm=a2g0o.productlist.0.0.30bf731a9zOEAe&algo_pvid=c98f543e-f988-4bc7-b26d-a7b85d6d3517&algo_expid=c98f543e-f988-4bc7-b26d-a7b85d6d3517-8&btsid=0ab6f82315952994418126684e7daa&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Avid Rabid Hobbyist
The following users thanked this post: NanoHawk
Online rstofer
« Reply #2 on: July 21, 2020, 07:04:08 am »
Dave sells a neat set of uSleeves
https://www.eevblog.com/product/usleeve/
Offline jpanhalt
« Reply #3 on: July 21, 2020, 09:15:21 am »
I get anti-static sleeve in a roll (about 1.5 to 2" flat).  Heat seal and cut.  Fold over open end and staple once.  That keeps it closed enough so stuff won't fall out, but you can reach in with forceps ("tweezers") to get a part out.  For longer strips, I just label the strip and save as is.
« Last Edit: July 21, 2020, 09:17:01 am by jpanhalt »
Offline agehall
« Reply #4 on: July 21, 2020, 09:49:21 am »
This: https://www.thingiverse.com/thing:3952021
I've started printing these for all my strips of components now as I need them. Sure, if you only have like 20-30 components in a strip, this might be overkill, but for things like resistors where you might as well just order 1000 even if you just need 10, this is great!
Offline Vovk_Z
  • Country: ua
« Reply #5 on: July 21, 2020, 03:38:23 pm »
+1 to a book-like storage. I have bought a 0805 and 1206 resistor kits (about 170 nominals each from 1 Ohm to 10 MOhm) - and it takes space only of a book. Very compact and convenient.
Offline Vovk_Z
  • Country: ua
« Reply #6 on: July 21, 2020, 03:41:41 pm »
I agree, but we usually need such a large amount of parts only of a few popular values - for example, 1k, 10k, 100k, and that's all.
« Reply #7 on: July 21, 2020, 10:27:13 pm »
THANK YOU!  This is exactly what I was looking for.
The film negative style sleeves are a great idea too.  I'd love to support Dave but $25 AUS plus 3 toes and a hand for shipping ..... buggers!  I will probably order a blank book from China Express (aka AliExpress).
The mini-cartridges are absolutely perfect..... definitely overkill for 5 or 10 parts, but great for things I use a bunch of like passives that are .01/ea from Taday with a 50 pc minimum.
« Reply #8 on: July 21, 2020, 10:34:45 pm »
IIRC you can order additional sleeves for the SMD books.....somewhere I saw them offered eons ago.
I've just written the values on pockets with a Sharpie but there's plenty of length in each pocket to cross a value out and write something else if required.
You could even get away with just writing a value for each decade if you didn't want to deface the pages too much.
Avid Rabid Hobbyist
Offline jmelson
« Reply #9 on: July 21, 2020, 11:52:14 pm »
I use Akro-Mils bins for lots of parts, I have more than half a dozen of them near my workbench.
Since I have a pick and place machine, I also have a lot of reels of parts.  I often cut off the last couple of feet of a reel and put that in the drawers for hand assembly.
Anything that is not a specific part only used in one project goes into a drawer.
If you start doing more boards, a P&P is the only way to go.  I just bought my SECOND machine.  I have been using a Philips CSM84 for almost 13 years, it isn't accurate enough for fine-pitch parts.  So, I just bought a Quad QSA-30A in an auction.  I have to get feeders and get it running.
Jon
Offline langwadt
« Reply #10 on: July 22, 2020, 12:08:34 am »
there are empty books and pages on ebay
Offline basinstreetdesign
« Reply #11 on: July 22, 2020, 03:40:05 am »
+1 for pocket pages.  I use them here:  https://imgur.com/a/jNQojEp
I got these at a philatelic supply store but they can be had at any hobby/crafty shop.
STAND BACK!  I'm going to try SCIENCE!
Offline tooki
« Reply #12 on: July 22, 2020, 04:30:19 pm »
They're not colloquially called tweezers, they are called tweezers outside of the medical field.
Offline jh15
« Reply #13 on: July 24, 2020, 06:26:34 pm »
Dave's pouch page says free postage to anywhere.
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
