.However, you didn't explain how the 2nd base or the 3rd base works. I think it may help some people here,.
If you could work in the concepts of holes vs. electrons, exchange of charges, emission of electrons, collection of majority carriers, etc., it would impress people more, potentially.
Not premium service, some original research required :p
Might not be fully related to the inner workings of common semiconductors
Well if you insist;
1.) First statement: The input resistance of an amplifier goes up if a voltage is fed back to the controlling inverting node and it goes down if a current is fed back. (These are basic rules from feedback theory).
This is ambiguous, because both voltage and current can be fed back in series or parallel.
I kindly ask you to answer two short questions:
a) Are both points 1) and 2) above, correct or not?
b) Can we derive from the observation in 2) any information about the question if a voltage or a current is fed back to the inverting node?
This also makes the question much more complicated than necessary, because you are talking about the impedance of a good capacitor: the FET case. The impedance is already infinite (nearly) at DC, but capacitive at high frequencies, neither of which is very easy to measure. What frequency should it be measured at? How are we to determine whether the feedback has an increasing or decreasing effect on it?
Quotelet me try a kind of summaryYou don't seem to be able to understand it on a device level, nor a circuit level - both of which we have tried on you.
In all my 25 years as an RF designer I've never ever heard any of my colleagues argue/bitch over the labelling of how a BJT is 'controlled' in terms of voltage or current.
In reality some of them fail to transfer and these are seen as wasted electrons that uselessly flow to the base. But the idea is that they nearly all transfer to the collector load resistor.
Here is another attempt - which I indicated quite a while for you.
The following is a simulation of two ideal devices, G1 on the left is a voltage controlled current devices and F1 on the right is a current controlled current devices. Both are configured into a gain stage.
The graph shows a dc sweep where Vin goes from 0v to 100mv, and Vout1 / Vout2 goes from 5v to 4v, as expected - Vout2 was shifted upwards by 0.1 so it is not right on top of Vout1.
Now, F1 and G1 are completely different devices in that one is voltage-controlled and the other is current controlled.
Question for you, which of them is a bjt and which is a mosfet?
:0
:0Thanks for posting that.
Indeed the response is the same, irrespective of whether it's current or voltage controlled.
Now look at the input impedance of the current controlled amplifier and you find it's pretty similar to what you'd expect from a BJT amplifier.
But the situation changes as soon as we have to explain to somebody else WHY the BJT (or a circuit with a BJT) shows a certain behaviour.
So it seems we need to argue about this instead. Is the lift on a wing produced by pressure or by air flow?
Pressure. If it were angle of the wing, a wing with the bottom surface parallel to the ground (or perpendicular to the force of gravity) would not generate lift.
Also, I am not sure if you intended this, but the air-flow / pressure are one and the same explanation.
I'm glad we agree about that.
i've been chatting with a few ex collegues on this.
It is really very simple
A bipolar transistor as amplifier has two defining parameters :
the common emitter current gain is called Beta ( or hFE)
the common base current gain is called Alpha
both are .... ratios. <- fill in the blank ....
Of course - we all know what's really controlling the things:
This dude, and a bit of magic smoke to keep him happy
Oh, I am intimately familiar with the base, she always claim she needs noting, but we all know that current is what she craves, just a little bit she says, but we all know it ends up being much more than that, often way beyond our budget, but what can we do, she needs the current now to perform what we expect of her.
Where does his poop and pee go?!?!
Common sense will indicate it will go to the collector, but it goes into the emitter.
That depends on whether it's NPN or PNP...
definitely a Poop 'N Pee so collector it is (I think)
You talk as if these are the only defining properties of the transistor and everything else necessarily falls out of them. I could say the same thing about the parameters of the Ebers-Moll equation, and I'd have a more accurate model as well (as yours doesn't account for anything translinear).
Also, these are only one parameter, each is directly a function of the other.
But the situation changes as soon as we have to explain to somebody else WHY the BJT (or a circuit with a BJT) shows a certain behaviour.Here I think lies the root of all the problems. You see, in physics and in science generally there is no answer to the question of why something happens. Science can only answer the question of what whappens, and what will happen.
We do experiments and gather data, and then we try to fit a mathematical model to the data. If we have a good model it will predict the results of other experiments we haven't done yet. If we have a bad model it will not, and we discard that model. The best models, the most convenient models to use, have fewer parameters that are easier to determine. We try to settle on the best models if we can, becaues they suggest we have somehow got "closer" to what is really going on.
So trying to ask what "controls" something else, if we mean anything other than what is the simplest model, is futile.
Imagine the following situation: Introducing the BJT I have stated that Ic is determined by Ib using the simple relation Ic=B*Ib.
Now - after some additional lessons - I explain the temperature dependence of the curent Ic and tell them that - in order to keep Ic constant - I must reduce the voltage Vbe by -2mV per degree temp. change.
Of course, some students will ask: Huhhh? We thougt it is the current Ib that controls Ic. Suddenly it is the voltage Vbe? (That`s what I have experienced often.)
And why this value of -2mV/K ?
