Author Topic: Voltage Booster  (Read 1765 times)
Offline skillz21Topic starter
Voltage Booster
« on: April 16, 2016, 11:22:02 am »
i was trying to build a voltage booster. and i was failing pretty badly, check out my schematic for proof. the capacitor was 10uF and it is an arduino uno (Rev3). i am sorry for the messiness, i am in a bit of a hurry. so when i did this, the arduino started to make a weired noise. like it had a buzzer... What? it started making a faint beep. why is this happening? is this harming my arduino?And if you guys can, can you link in the simplest voltage booster you can find? i need to step around 4.7v to around 9v.
Offline danadak
Re: Voltage Booster
« Reply #1 on: April 16, 2016, 12:03:28 pm »
Good chance you have fried the Arduino.
Basics - https://www.maximintegrated.com/en/app-notes/index.mvp/id/2031
Regards, Dana.
Offline Seekonk
Re: Voltage Booster
« Reply #2 on: April 16, 2016, 12:24:07 pm »
I could tell you how to do it, but you are probably in too much of a rush to read it.  You schematic likely has nothing to do with how you actually wired it.
