Author Topic: Where's my dead time??  (Read 6869 times)
Offline danadak
Re: Where's my dead time??
« Reply #25 on: January 16, 2017, 11:56:08 am »
These might help, attached.
Regards, Dana.
Offline HackedFridgeMagnet
« Reply #26 on: January 16, 2017, 10:14:12 pm »
Flyback diodes? seems now like the obvious solution to the 700 volts.
Offline peter.mitchell
« Reply #27 on: January 16, 2017, 11:06:09 pm »
your FETs are insufficiently rated.
the IRFP460 is rated to 500v, you need 650v~ absolute minimum.
when one FET turns on, the other FET will see 2x+ the supply voltage because the primary will act as an autotransformer.
if line voltage is 230vac, thats 325vdc peak rectified,2x that is 650.
