Those are ferrite beads for noise/EMI suppression?Or are they made out of plastic? It is not clear from the pictures.The one on the capacitor looks too big to be a ferrite bead.
Ferrite beads are one of the options to suppress snap recovery in a line frequency rectifier which would otherwise cause objectionable 100/120 Hz buzz. Audio circuits are especially susceptible. I prefer to use small capacitors in parallel or diodes which do not suffer from that problem. It is an obscure problem.Maybe someone replaced the rectifiers and put the tubing there in place of the original ferrite beads, or whoever assembled the board cheaped out?
As for the hypothesis, that this is a bodgy repair: the tubes seem to be a part of the original design. Another source showing a similar thing.
Yes, I agree, they are original fit spacers to ensure that the diode body doesn't drop down and sit directly on the PCB during flow soldering. This is particularly important on SRBP PCBs, where hot components need some standoff to avoid prematurely degrading the board. Sitting flush would put excessive mechanical stress on the diode body too.
That actually makes some sense to me...as spacers. The use on the larger caps, however, is sporadic and the spacers are longer, consistent with lead insulators. Note though that those caps were pushed together and glued (I cleared them out to see the IC). But, you can see one cap with one spacer, and the one next to it with none and another with two.
