Author Topic: Worthless rotary encoders  (Read 5307 times)
Offline Jan AudioTopic starter
Re: Worthless rotary encoders
« Reply #25 on: April 25, 2021, 03:34:02 pm »
I have to measure a pin with my multimeter to see if i am around that 500KHz.
Offline madires
  • A qualified hobbyist ;)
« Reply #26 on: April 25, 2021, 04:48:46 pm »
I've found that you pretty much need to sample at 500Hz or faster to avoid missing pulses.
And I'd recommend to design your algorithm to be able to cope with bad Gray code steps because the cheap encoders don't create nice and clean pulses as good encoders do. There can be a huge difference in timing and bouncing behavior.
Offline xavier60
« Reply #27 on: April 26, 2021, 01:08:56 am »
The transitions can be very close together so I poll at 1mS.
On each change, I Left shift the A and B bits into a 6 bit register then test for 0x12 or 0x21 for up/down.
I use RC filtering and apply a drop of PAO oil to the encoder to stop it from becoming scratchy with time.
It also helps for the input ports to be anything but TTL level.
Putting capacitors directly across the encoder contacts without  series resistors can cause discharge spikes resulting in miscounts.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
« Reply #28 on: April 26, 2021, 01:22:32 pm »
I sample at 35KHz.
Cant have 500KHz in a 8-bit PIC.
Offline tszaboo
« Reply #29 on: April 26, 2021, 01:48:02 pm »
I sample at 35KHz.
It was 500 Hz, not KHZ.
35KHz should be enough to catch all pulses IMHO. I mean with a really good confidence, with not superhuman scrolling speeds.
You get usually surprises, when using Arduino with some badly designed blocking libraries.
« Reply #30 on: April 26, 2021, 01:58:21 pm »
Ah ok thanks, i readed it to fast.
All my code is custom without blocking, fastest non-asm code with free mode in the west.
Offline szszoke
« Reply #31 on: April 26, 2021, 03:37:18 pm »
I am using rotary encoders for my project that always give pulses when it is being turned.
I debounce the signal with a couple of 10k resistors and 100nF capacitors.
Both pins (let's call them A and B) pulse when the encoder is moved by one detent.
Depending on the direction, either A or B will be pulsed first.
Because of this behavior, I can essentially use one pin as a "clock" which would trigger a pin change interrupt, and inside that interrupt I can read the state of the other pin. The state of that other pin will give me the direction.
I tried the polling method as well but it kept not working and kept missing pulses when I turned my encoder faster.
I am not missing steps this way, and the hardware debouncing ensures that I have clean pulses.
If nothing else works, maybe you can give this a try.
Offline tooki
« Reply #32 on: April 26, 2021, 06:53:38 pm »
personally I don't know any encoders which don't do gray code output, so I'm a bit surprised that you struggle with it now.
never mind whether I used magnetic, optical or mechanical encoders, they all worked the same way, with same code on mcu side
most of my projects run with those cheap china encoders, never had any unexpected behaviour with them
If "EC11" refers to being compatible with ALPS EC11 series then the rotary encoders should have two Gray code steps per detent. However, most cheap rotary encoders have four Gray code steps (complete Gray code sequence) per detent. You can check that also with an inexpensive USB-based logic analyzer, if you don't have a multi-channel scope.
Incremental encoders like EC11 are not Gray code, but quadrature. Actual Gray code is used in absolute encoders.
Offline jesuscf
« Reply #33 on: April 26, 2021, 09:16:14 pm »
Quadrature encoders produce 2-bit Gray code:
00 -> 01 -> 11 -> 10 -> 00 etc.
Homer: Yeah, but faster!
The following users thanked this post: madires
Offline xavier60
« Reply #34 on: April 27, 2021, 12:04:08 am »
All cheap mechanical rotary encoders that I have purchased on ebay have been the type where A and B momentarily turn on between dents, always off at each dent.
This sort of thing, https://www.ebay.com.au/itm/311947024355?hash=item48a17dd7e3:g:wbAAAOSw7ZlZoZDq
Offline xavier60
« Reply #35 on: April 27, 2021, 01:44:32 am »
After a lot of searching, this is the only mention I have found about the 2 types, https://forum.arduino.cc/t/strange-rotary-encoder-problem/483892/4
Offline madires
« Reply #36 on: April 27, 2021, 11:39:05 am »
Those create four Gray code steps per detent (see the diagram posted by jesuscf). The number of steps is important for encoders with detents because you want to align the change of some value with the detents for proper user feedback. For encoders without detents, which turn freely, it's not that important.
Offline xavier60
« Reply #37 on: April 27, 2021, 12:00:56 pm »
Many timing diagrams don't show the dent positions, causing ambiguity.
This example shows the 2 dent positions, https://tech.alpsalpine.com/prod/e/html/encoder/incremental/ec11/ec11_common.html
« Reply #38 on: September 13, 2021, 01:41:44 pm »
Ok they do work.
I was tired of this problematic hobby and quitted a while.
They are ok i still need to find some problem, no impulses on 1 line, cable is good.
Offline rstofer
« Reply #39 on: September 13, 2021, 03:30:12 pm »
Maybe i should try interrupts then.
Yes i have a display, my other project also works.
Need to order those blue ones i think.
Interrupts are for doing a fixed sample rate.
(i.e. NOT Interrupt-On-Change of the pins as I've seen so many do.)
Interrupt-On-Change can overload your processor.
Interrupt on change is very fast when implemented as a state machine and table driven.  It also takes care of bouncing (generally) by looking only for expected edges for the interrupt on change.
Here is some very credible code that is nearly identical to what I wrote years ago.
https://github.com/buxtronix/arduino/blob/master/libraries/Rotary/Rotary.cpp
Sampling burns a lot of CPU cycles for nothing when the encoder isn't being used and the sample rate needs to be quite high.
With interrupt on change, no cycles are used unless the encoder is actually changing positions.  It's pretty clear that if we just did an interrupt on change for the falling edge of a signal, we need to change the interrupt direction to interrupt on rising edge.
Google for 'rotary encoder interrupt driven state table'
« Last Edit: September 13, 2021, 03:44:41 pm by rstofer »
Offline rstofer
« Reply #40 on: September 13, 2021, 03:34:12 pm »
I found my code written for some variant of the ATmega128.  This was written for wheel encoders on a small robot so the signals are changing pretty fast.  It also counts +4 for a complete transition.  It counts each transition as + or - 1 depending on direction.  This will need to be rethought for panel encoders but the idea is right.  The interrupt handlers are pretty short!
#include <avr/io.h>
#include <avr/interrupt.h>
#include <stdio.h>
#include <ctype.h>
#include "defines.h"
volatile int8_t  RightWheelState = 0;
volatile int32_t RightWheelCount = 0;
volatile int8_t  LeftWheelState  = 0;
volatile int32_t LeftWheelCount  = 0;
volatile uint8_t urx;
volatile uint8_t urx_recv;
/* Quadrature Encoder Scheme
 * There are two pairs of quadrature signals, one for each wheel.
 *      The right wheel is on EXINT4 (PE4) and EXINT5 (PE5)
 *      The left  wheel is on EXINT6 (PE6) and EXINT7 (PE7)
 *      Each encoder has two outputs A & B.  For convenience, A is considered the MSB
 * while B is considered the LSB.
const int32_t EncoderB[] = {+1,-1,-1,+1};
const int32_t EncoderA[] = {-1,+1,+1,-1};
SIGNAL(SIG_INTERRUPT4) // encoder B for right wheel
EICRB           ^= 0x01; // toggle the edge bit
RightWheelState ^= 0x01;
RightWheelCount += EncoderB[RightWheelState];
SIGNAL(SIG_INTERRUPT5) // encoder A for right wheel
EICRB         ^= 0x04;
RightWheelState ^= 0x02;
RightWheelCount += EncoderA[RightWheelState];
SIGNAL(SIG_INTERRUPT6) // encoder B for left wheel
EICRB          ^= 0x10;
LeftWheelState ^= 0x01;
LeftWheelCount += EncoderB[LeftWheelState];
SIGNAL(SIG_INTERRUPT7) // encoder A for left wheel
EICRB          ^= 0x40;
LeftWheelState ^= 0x02;
LeftWheelCount += EncoderA[LeftWheelState];
void IOInit(void)
UBRR0H = 0;
UBRR0L = BAUD;
UCSR0B = _BV(RXEN) | _BV(TXEN) | _BV(RXCIE);
static int uart_putchar(char c, FILE * stream)
if (c == '\n')
uart_putchar('\r', stream);
while (! (UCSR0A & _BV(UDRE)))
UDR0 = c;
return c;
SIGNAL(SIG_UART0_RECV)
uint8_t s;
s = UCSR0A;
urx = UDR0;
if (bit_is_clear(s, FE))
urx_recv = 1;
void QuadInit(void)
LeftWheelState  = (PORTE & 0xC0) >> 6;
RightWheelState = (PORTE & 0x30) >> 4;
EICRB = 0xff;                           // enable rising edge triggering on INT4..7
EICRB ^= (LeftWheelState  & 0x02) << 5; // if a signal is already set
EICRB ^= (LeftWheelState  & 0x01) << 4; // set the interrupt to falling edge
EICRB ^= (RightWheelState & 0x02) << 1;
EICRB ^= (RightWheelState & 0x01);
EIMSK = 0xf0;                           // enable these 4 interrupts
int main(void)
IOInit();
QuadInit();
sei();
fdevopen(uart_putchar, NULL);
printf("Hello World\n");
while (1) {
printf("LWS =%2d LWC =%6ld RWS =%2d RWC =%6ld\n",
LeftWheelState, LeftWheelCount, RightWheelState, RightWheelCount);
[/font]
« Last Edit: September 13, 2021, 04:02:14 pm by rstofer »
Offline Old Printer
« Reply #41 on: September 13, 2021, 04:26:19 pm »
Post a scope trace.
I have a single channel analog scope.
Waiting for a modern scope to come out anytime soon with better specs.
I assume you are kidding?? :-//
