Loading [MathJax]/extensions/Safe.js
Author Topic: changing the rigol DS1052E to DS1102E using USB , the dummy guide  (Read 1431265 times)
Offline Totoro
    • The Belfry
Re: changing the rigol DS1052E to DS1102E using USB , the dummy guide
« Reply #1625 on: November 13, 2014, 02:17:48 pm »
I just wanted to chime in. After finally getting communication with the oscilloscope setup I decided to try the modification. And it worked! I am using Python with the PyVISA library and the National Instruments VISA implementation. My 'scope is a DS1052E with 2.6.0.1 and hardware version 58.
I did a downgrade, executed the :INFO commands (:MODEL followed by :SERIAL) and upgraded back to 2.6.
Thank you to all for your work in getting this figured out and documented and making the necessary files available!
Here a couple of screen shots from the before and after as well as the little fast rise time oscillator I put together to make the tests.
Offline straycat
« Reply #1626 on: December 06, 2014, 01:39:36 pm »
Hay guys. The new fw 00.04.01.07.00 is easy to change the same way you do the others. Having ripped the fw apart with others you can change anything on it I.E the fw version too. Simple.
Offline sergey.onliner
« Reply #1627 on: December 18, 2014, 10:36:25 am »
Here we go, latest firmware update (00.04.01.00.02) with 100Mhz mod.
CRC32: 4EF27EF4
MD5: b3be022a8890c7448ed68a189c1071b1
And kindly also hosted more permanently here:
http://jahansen.com/rigol/DS1000EUpdate.00.04.01.00.02.zip
Gizmo
Hi all!
I'm another owner DS1052E. I have only one question:
is it possible use this file for update my scope
Model: DS1052E
Serial No: DS1ET16326xxxx
Software version: 00.04.01.00.02
DSP: 00.01
FPGA: 03.07
HardVersion: 58
Sorry for my English.
Offline agmbass
« Reply #1628 on: December 21, 2014, 09:06:45 pm »
Hi Gizmo, hi GreySam
Sorry for the "Me Too" Post. I'm owner of a DS1052D with Firmware 00.04.01.00.02 too. I also want to upgrade my 50MHz Model to 100 MHz and i'm wondering if anybody have a "patched" firmware for the ds1052d...? Maybe its already answered in this thread, by i got lost after hours of reading...
GreySam, have you any further investigations to "our case"?
Thanks in advance.
    queaker
If you search the 1052D update flash for :
E5 01 00 A8 61 08 08 05 10 09 60 89 E6 7D 00 50
and replace with
E5 01 00 A8 61 08 08 05 10 01 60 89 E6 7D 00 50
(Change the 09 for a 01 at offset 9)
Then flash with that firmware, you should be working at 100Mhz. One other person, zdoe, did this last july. If you ask him nicely he may still have his custom flash file (although I dont remember the version)... :)
Hi Gizmo,
thank you very much for your help, your patch works on 1052D with latest FW 00.04.01 SP7.
You are the greatest  ;)
GreySam
Thank you for the info ... just did it to my 1052D with firmware 00.04.01 SP7
Offline Analog Dude
« Reply #1629 on: December 29, 2014, 06:07:22 am »
Hi-
I'm new to this forum.  I have a DS1052E with 00.04.01 SP7 at 50MHz and want to upgrade it to 100MHz.  I tried updating it with modified 00.04.01.00.02.  The scope recognizes my USB stick but does not give me an option to upgrade.  Is there a version of FW out that will work and is accessible.?
Thanks much.   ^-^
Offline straycat
« Reply #1630 on: December 29, 2014, 02:50:23 pm »
Analog Dude. make sure the fw is not in a folder or zip file. Put the fw direct on the usb stick and the scope should pick it up. hope this helps..
Offline straycat
« Reply #1631 on: December 29, 2014, 02:55:02 pm »
CRC32: 4EF27EF4
Gizmo
Hi all!
Model: DS1052E
DSP: 00.01
FPGA: 03.07
HardVersion: 58
The answer is yes,.Use the patched FW on a usb stick.. Hope this helps.
Offline Analog Dude
« Reply #1632 on: December 29, 2014, 10:35:39 pm »
Hi Stray Cat-
I did put the RGL file on the root directory.  Nothing else on the memory stick.  As I said, the DS recognises the USB stick but doesn't offer to upgrade.  My guess is that it sees the 00.04.01.02 software as older then the 00.04.01 SP7 that is on it.
I had put updated the firmware on the scope to 00.04.01 SP7 previously using the same memory stick.
Thanks.
Offline Analog Dude
« Reply #1633 on: December 30, 2014, 06:40:23 am »
Hi all,
It seems I need 00.04.01 SP7  (which I believe is the same as 00.04.01.07.00) or later to do the upgrade.  Is this available?
Thanks.
Offline MudMan
« Reply #1634 on: December 30, 2014, 11:50:45 am »
If the link a few post above doesn't work, try this one: http://www.mikrocontroller.net/topic/261138#3815212
Offline Analog Dude
« Reply #1635 on: December 30, 2014, 09:00:15 pm »
Thanks MudMan-
That worked.     :)
Offline corsaore
« Reply #1636 on: January 02, 2015, 09:40:44 am »
Thanks MudMan-
That worked.     :)
Step :
1 download the files http://www.mikrocontroller.net/attachment/231159/DS1000EUpdate_00.04.01.07.00_100MHz.zip
2 Usb key format fat 16/32
3 unzip the file into root usb key
4 plug the usb key in rigole 1052E
5 message upgrade FW choice ok in the menue
THX  for the forum support is greet
Offline mmatic
« Reply #1637 on: January 06, 2015, 06:52:35 pm »
Hey!
I bought and hacked Rigol DS1052E firmware a few years ago. Is there any new firmware available?
My version:
serial no: DS1EB125116783
SW version: 00.02.04 SP1
installed module:
- FFT
- USB
- P/F
-RS232
Best Regards Matic
Offline straycat
« Reply #1638 on: February 05, 2015, 06:39:10 pm »
Hi guys just a quick question... When using the scope the BANDWIDTH LIMITER auto switches to on. Does anyone else have this problem?
« Last Edit: February 05, 2015, 06:44:45 pm by straycat »
Offline lilogre
« Reply #1639 on: March 11, 2015, 04:44:32 pm »
Hey everyone.
Just wanted to say a quick thanks to everyone who has worked on this project.  I just received my DS1052E in the mail yesterday.  Fired it up, plugged in a usb stick with the modified 00.04.01.07.00 firmware from Corsaore's last post...  worked like a charm.  Thanks again everyone!
Regards.
Offline neonhomer
« Reply #1640 on: March 16, 2015, 05:41:53 pm »
Has anyone done this recently? I just picked up a 1052E and am looking forward to having a scope, but also being able to save $70 by using the software mod.
NeonHomer
"No Matter Where You Go, There You Are"
Offline The_PCB_Guy
  • PCB Enthusiast
« Reply #1641 on: March 16, 2015, 09:19:18 pm »
I did it a few months ago. Unzip this file and put the RGL file on a flash drive. Then follow the instructions mentioned earlier in this thread to upgrade the scope.
Good luck!
Matt
EDIT: Sorry, file is 1399kB, and this forum only allows up to 1000. Had to go with a sendspace link instead: https://www.sendspace.com/file/hasl0h
The_PCB_Guy
Offline neonhomer
« Reply #1642 on: March 17, 2015, 01:28:14 am »
Thanks. I will try it when I get it and see what happens...
That is if it ever ships... LOL....
NeonHomer
Offline neonhomer
« Reply #1643 on: March 21, 2015, 02:20:47 am »
Well, I tried putting that file on an empty flash drive, putting it into the scope, rebooting it and nothing....
I think mine has a newer version of the firmware.... 00.04.01.07.00 (00.04.01 SP7)
I would try the hex hack, but I don't have this firmware to edit....
I tired both the version you linked, and the MudMan link... and neither will prompt the scope to update...
NeonHomer
Offline The_PCB_Guy
  • PCB Enthusiast
« Reply #1644 on: March 22, 2015, 02:47:33 am »
1) Did you ensure you unzipped the file, and ONLY had the .rgl file on the flash drive?
2) Did you ensure the flash drive was formatted properly? I think it needs to be formatted as FAT32, not NTFS (Please read the thread to verify this)
The_PCB_Guy
Offline neonhomer
« Reply #1645 on: March 24, 2015, 01:26:56 am »
Yes... only the RGL file was on the drive.
I tried formatting it as FAT32 and FAT16.
***EDIT - Well, I was using a 4GB flash drive that was given to me from a training class I took (branded Schneider Electric, don't know who actually made the thing). For the laughs of it, I took an old 1GB flash drive and tried it. Still wouldn't see the file.
I finally took a USB media card reader, and put the file on a 1GB SD card. Plugged that into the scope and it greets me with the same version message. Write it to the scope and it worked! I'm now at 2ns!
Guess it didn't like the 4GB stick... even though I could write to it with the scope with no problems... Weird...
Now... Time to crack into the project that prompted me to buy this scope in the first place.... getting my Tektronix 485 back running!
« Last Edit: March 24, 2015, 01:42:43 am by neonhomer »
NeonHomer
Offline jamrock
« Reply #1646 on: March 29, 2015, 02:47:47 am »
Does anyone have the MD5 checksum for the 00.04.01.07.00 hack firmware. Want to ensure file is ok before loading to scope.
Offline PoWl
« Reply #1647 on: April 01, 2015, 09:24:03 pm »
Hi there,
i recently discovered the possibility to hack my DS1052E so i instantly checked the firmware version of my scope. It's a 02.05 SP2 (00.02.05.02.00), HW 58 which makes it necessary to downgrade it to version 02.02.
I've seen the post which is linked at the first page concerning the downgrade: https://www.eevblog.com/forum/blog/changing-the-rigol-ds1052e-to-ds1102e-using-usb-the-dummy-guide/msg42404/#msg42404
Unfortunately the hacked upgrade-file to downgrade the scope from 02.05 SP2 to 02.02 SP2 which is mentioned in the post by A Hellene is down, respectively all attachements before a certain date are not available anymore  :(  although A Hellene has described what he has done i'm not sure enough to do it by myself. I don't want to brick my scrope. So can anyone send me the right upgrade-file oder show me a download-link? (Maybe it's somewhere between page 42 and 110, I skipped through the pages on a random basis but coudn't find any helpful hints and I don't have time to read the whole thread. Actually, I originally didn't want to make a big deal of hacking the scope  ::) )
Thanks for any hints and help!
Btw sry for my bad english,
regards from Germany ;-)
Paul
Offline MudMan
« Reply #1648 on: April 05, 2015, 03:47:34 pm »
Why don't you update to the newest cracked version? No need to downgrade, change serial number and re-upgrade?!?
Offline Velund
« Reply #1649 on: April 05, 2015, 04:22:12 pm »
Someone may prefer to have a scope that can be updated by stock firmware and still retain all features.
Unfortunately, all files that was used to downgrade my own scope in the past was lost in HDD crash.
