Author Topic: changing the rigol DS1052E to DS1102E using USB , the dummy guide  (Read 1316149 times)
Offline mattb.351
Re: changing the rigol DS1052E to DS1102E using USB , the dummy guide
« Reply #975 on: February 25, 2012, 10:53:46 am »
Am I missing something? All the files for downgrading to 2.02 from other versions are available. What I cannot find is the 2.05.02 downgrade file. Any pointers? Thanks in advance...
Offline timotet
« Reply #976 on: February 25, 2012, 06:49:15 pm »
try page 59 of this post :D
Offline srmahaffy
« Reply #977 on: February 26, 2012, 07:29:32 am »
 8)Hi, I am a newbie, and wanted to thank everyone for the great write up on how to upgrade a DS1052E to a DS1102E. I felt nervous and scared to do the upgrade because I wasn't sure if I could understand everything, but with time to digest it I did! Shafri's program made it extra easy too. Thank you!!  8)
Offline mattb.351
« Reply #978 on: February 27, 2012, 01:10:37 pm »
Thanks timotet, I just couldn't find that. 100MHz here I come!
Offline rar
« Reply #979 on: March 07, 2012, 06:51:21 am »
Successful upgrade from DS1052E 00.02.06.00.01 HV=58 to DS1102E 00.02.04 SP1, following the standard procedure described here exactly.  Everything went like clockwork!  ;D
Carefully read the one page!
Thank you!
Offline danander11
« Reply #980 on: March 08, 2012, 09:16:42 am »
Another happy customer here wishing to offer a huge THANK YOU! to everyone involved..  (not the least of which is Rigol for not locking this off).
I've gone from 0.02.06 to 0.02.04 SP1.    Has anyone going all the way back up to 0.02.06 noticed any issues?
Thanks again!
Online Fraser
« Reply #981 on: March 08, 2012, 03:39:19 pm »
The best advice I can offer is to stay with 2.04 SP1
Higher versions do not appear to have added worthwhile improvements and as many manufacturers state...if you do not have any problems with the firmware you are running DO NOT upgrade your version. Its often a numbers game...a later version number must be better right ?....not necessarily so and it is my opinion that this applies to the DS1052E. I know of no nasty issues with 2.04SP1 but 2.05x had some real nasties such as crashing and awful screen flicker. No idea about 2.06 but Rigol advised me that all versions later then 2.04SP1 were purely "housekeeping" changes ....i.e. attempts to prevent changing the 50MHz DSO into a 100MHz DSO.
You can always update to 2.06 if you find a bug in 2.04SP1 but I advise patience and not to upgrade just because it's available.
Aurora
« Last Edit: March 08, 2012, 03:41:30 pm by Aurora »
Offline PolossatikTopic starter
« Reply #982 on: March 08, 2012, 05:10:27 pm »
been a while since i've updated the first page.
can someone point me to the lasted bundle of files and up to what version they are fine?
i'll then update page 1
(please PM me)
edit: 151677 Views .... W00T
Real Circuit design time in minutes= (2 + Nscopes) Testim + (40 +120 Kbrewski) Nfriends
Testim = estimated time in minutes Nscopes= number of oscilloscopes present Kbrewski = linear approx of the nonlinear beer effect Nfriends = number of circuit design friends present
Offline rar
« Reply #983 on: March 08, 2012, 06:54:41 pm »
Updated to 2.06.00.01.
So far everything is OK!
Offline treebeard
« Reply #984 on: March 15, 2012, 01:24:25 pm »
I would like to thank those on this blog who put this together.  I
successfully upgraded my recently purchased DS1052E to DS1102e.  Wonderful.
No problems whatsoever. I purchased the unit from Amazon $355 on Monday.  http://www.tequipment.net/
sent it out FedEx(!) wow..
Thanks again!
Treebeard
Offline artico78
« Reply #985 on: March 28, 2012, 09:38:31 am »
Some people tell its not possible to hack rigol with 2.06 firmware, can someone made an updated guide with updated files, cos some files are not avalaible for download. Thank in advance
Offline artico78
« Reply #986 on: March 28, 2012, 10:17:27 am »
Someone have the same type of guide for 2.06??? Its really good work :)
Thanks for the great tutorial and the help of the repliers!
Because I did not find any downgrade file for the 02.05.SP2 scopes, I just edited a file for the older fw versions and checked it to the md5 sums.
It worked. 'Till now i dont see any problem with the firmware either.  02.04.SP1 is OK.
I made a package for newcommers. Feel free to use it...
https://rapidshare.com/files/1870851383/rigol_upgrade_tools_for_DS1052E_02.05.SP2.zip
Read the instructions and also the Blog before using it!!!
Offline A Hellene
  • Country: gr
« Reply #987 on: March 28, 2012, 07:36:52 pm »
Ah, come on guys!
It is here and it covers all the known FW versions up to v2.06 (02.06.00.01) included.
-George
Hi! This is George; and I am three and a half years old!
(This was one of my latest realisations, now in my early fifties!...)
Offline icon
« Reply #988 on: April 03, 2012, 10:35:58 pm »
Hi
Many thanks to the people who put the work into creating and documenting this hack. I've just upgraded a 2.06.00.01/HW58 using the tools linked to. All the info is in this thread; just read and research and read again!
Just to reinforce - check your hashes *on the USB stick*, and check them again. Being paranoid, I put the 'scope and the computer on a UPS.
A small point - the first post states (in red): "The downgrade is currently only possible for scopes who come with an firmware up to 00.02.05.02.00" - this is clearly no longer true, as the post goes on to make clear. This could be confusing some folks?
Thanks again.
John
Offline ming3761
« Reply #989 on: April 06, 2012, 05:39:49 am »
Help! First of all.thanks a lot to those who provided the approach to hach the rigol ds1052E.HOWEVER,after my rigol being hacked?it can not connect to the computer any more,neither via usb or serial port, I really what it to do acquisition with labview.
who can give me a solution? My appreciation to you is beyond word.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #990 on: April 07, 2012, 01:46:54 pm »
Can anyone with a hacked 1052e Rigol check if your serial ports and USB ports are still active?  This is a fairly concerning flaw if its true, and its the first I've heard in over 3 years of people hacking the Rigol.
« Last Edit: April 07, 2012, 01:51:43 pm by saturation »
Best Wishes,
 Saturation
Offline icon
« Reply #991 on: April 07, 2012, 03:20:42 pm »
I've just checked mine; it works fine on USB (I don't have any way of checking the serial port). I was on 2.06.01, now 2.04 SP1. H/W 58.
John
Offline saturation
    • NIST
« Reply #992 on: April 07, 2012, 05:01:52 pm »
Thanks icon, that's good enough!
John
Best Wishes,
 Saturation
Offline ming3761
« Reply #993 on: April 09, 2012, 11:09:44 am »
John
Thank you, icon. You made me regain the confidence to tackle this problem. From the point view of repeatability of scientific experiment, if we have the same experimental object and the same experimental method, the result should be the same. The first condition is confirmed, so the cause may be different in method. As I have flashed it many times, I’ll just narrate the last time I do the hack.
1.   modify the first 21 bytes of 2.02 firmware.
2.   downgrade the rigol,then use the “rigupgr” tool,change it’s model and serial num to DS1102E.(still can connected)
3.   modify the first 21 bytes of 2.04 sp1
4.   upgrade the rigol to 2.04 sp1(no response to the usb plug,at winxp just no echo at all,at win7,it noticed that no id firmware only at the first time it plug with usb)
Is there any wrong with my procedure?
I found a new phenomenon last night: the rigol can be connected during a short period of power on, and it recognize as a hid device, After that it disconnected and no response anymore.
Offline ming3761
« Reply #994 on: April 09, 2012, 01:28:20 pm »
My system info?
Offline icon
« Reply #995 on: April 09, 2012, 06:08:40 pm »
Quote from: ming3761
Hi
The only thing I did differently was I used the ready-patched 2.02 and 2.04 firmware linked to in this thread, and checked the MD5 checksum of the file on the USB stick to make sure it was correct.
Regards
John
Offline ming3761
« Reply #996 on: April 12, 2012, 12:50:19 pm »
Hi
Regards
John
[/quote]
I finally tackle this problem, It was all because of my carelessness. LOOK AT the picture, the serial number has a /n on the end, and that was the troublemaker.
     CONCLUSION:AnyONE who change the form of the serial number will lead to the Unable to connect to computer of the rigol scope.
  thank you for anyone who care about my trouble, now I can easily control my scope with relaxed labview programming.
Offline A Hellene
  • Country: gr
« Reply #997 on: April 12, 2012, 12:58:45 pm »
John, I am glad you managed to figure it out. I am sorry though but none of the pictures you have posted really made it over here, at the eevblog.com, since they all have been replaced by generic null images of the image hosting companies (hi.baidu.com and gonten.com).
-George
« Last Edit: April 12, 2012, 01:28:52 pm by A Hellene »
Offline icon
« Reply #998 on: April 12, 2012, 09:12:48 pm »
Hi
Confusion about who's posting what; Ming is the one with the null images - I'm the other one.
John
Offline A Hellene
  • Country: gr
« Reply #999 on: April 12, 2012, 09:27:41 pm »
Oops... You are right, John. It is obvious I was addressing Ming.
It seems that the broken quotation containing your signature, at Ming's message before my previous one, is what got me confused. I am sorry about that.
-George
