Author Topic: EEVblog 1512 - Why Bypass Your PCB Like THIS?  (Read 8407 times)
Online EEVblogTopic starter
« on: November 02, 2022, 01:39:28 am »
Offline Bud
Re: EEVblog 1512 - Why Bypass Your PCB Like THIS?
« Reply #1 on: November 02, 2022, 04:18:15 am »
PCB designers who do not know electronics ??  :wtf:
Did I hear that right?
« Reply #2 on: November 02, 2022, 05:51:46 am »
Yes, I knew several that came from a drafting background.
PCB layout WAS drafting back in those days.
Offline johnh
« Reply #3 on: November 02, 2022, 08:56:51 am »
The small company ( 5 people)  that I worked at when I was getting work experience for the Certificate in Electronics back in 1978, had a pommy draftsman doing  the PCB layout using Bishop tape
Offline Kleinstein
« Reply #4 on: November 02, 2022, 09:02:42 am »
If they have to stick to the rather large footprint with spacing, than the simple grid is close to the best one can do.
There are still quite some 0 ohm resistors, that may or may not be required.
In the 1990s there was a time when fast chip supposed to have even more than 1 cap per pin, but a whole sereis of 1 nF 10 nf 100 nF - I never really understood and at least with modern 100 nF caps in 0402 or separate GND and VCC planes, there is no really need for this anymore.
Offline Fungus
« Reply #5 on: November 02, 2022, 09:43:56 am »
Check for unconnected capacitors.
If it was me I'd add dummy capacitors just to fill in the spaces if there were a couple of gaps left over after layout.  :)
Online Brumby
« Reply #6 on: November 02, 2022, 10:49:52 am »
Ah ... Your artistic perfectionist is showing through.   ;)
« Reply #7 on: November 02, 2022, 11:42:13 am »
Agreed, that would be compulsory on a grid layout like this.
Offline Fungus
« Reply #8 on: November 02, 2022, 03:43:27 pm »
Either that or my OCD.
Offline free_electron
    • SiliconValleyGarage
« Reply #9 on: November 02, 2022, 05:40:14 pm »
Oh yes. Lots of them. The reverse is equally true... lots of engineers think they know how to do a board ...not ! dfm ? never heard of it .. what do you mean parts can crack if they are too close to the edge ? not my problem. Why cant i use smaller drills and place them closer ? WTF is CAF ? Can't you just slow down the conveyer to increase the barrell fill ? ok , ok i'll use a larger drill ... what do you mean the part now "pushes out" and why is there solder all over the topside ? can't you lower the wave pressure ? what is tombstoning ? what is head-in-pillow ? why do i have all these voids under my thermal pad ? can't you use a better paste that doesn't void ?
The routing bit is the easy part... getting all other stuff right for production is a different story. sure, 1 or 10 boards is easy. try doing 10.000 boards or more a day with a maximum of 10 failures.
« Last Edit: November 02, 2022, 05:45:30 pm by free_electron »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #10 on: November 02, 2022, 08:16:28 pm »
(Just glancing in here, may be repeating some things.)  Also familiar about that design, the via-in-pad suggestive of internal routing or planes.  In particular I recall similar design practices on some old IBM network card (ISA Ethernet) I had, and on Tektronix boards particularly of the vintage of my TDS460.  Especially for Tek I think, and, not sure about others, I think the priority for inner layer routing was a...reliability thing?  Maybe frustrates RE too, I guess.
Seven Transistor Labs, LLC
Offline thm_w
  • Non-expert
« Reply #11 on: November 03, 2022, 09:05:52 pm »
There are lots of 0 ohm yeah, definitely none of them are actually required as jumpers. Probably just placeholders for series termination, current measurement, etc.
